Personally, if you are not concerned about gaining an extra half inch of ground clearance, I’d go with the 235’s as I feel the 1.5 liter is a little underpowered with the 245’s. I only did the 245’s because I bought the leveling kit and it will fill out the wheel well a little better. It still has some zip, but a noticeable difference, at least from stock. So I feel like the small gains might be worth it. I had the same debate too. Plus, a 235 can actually fit in the spare tire compartment. 245 raises it substantially.My biggest concern is the effect on take off and rolling acceleration and power. Woundering how much and how noticeable it is on the 1.5
That's going to be the deciding factor between 245/65's and 235's.
