Installing front license plate holder
jofer
This may be a bit of a silly thing to post, but hopefully it helps someone.
For whatever reason, my dealer didn't install the front license plate holder, even though I live in a state where they're required. They told me it was just a matter of drilling a few holes and screwing it in and I should be able to figure it out just fine. Took quite awhile to find the front license plate mount, but it was hidden underneath the spare tire.
However, the only mounting hardware was these odd nail things. (Yeah, I know, stop laughing at me...) There were also no instructions of any sort and I couldn't find anything online.
Ford Bronco Sport Installing front license plate holder PXL_20210529_142246759
So those are pop rivets, which took me way, way longer to figure out than it should have. (Yeah, I know, I'm not the brightest...) To use them, you need a rivet gun, which thankfully are cheap-ish ($20) and easy to find.
Ford Bronco Sport Installing front license plate holder PXL_20210529_142831987
You'll need to drill three holes in the front bumper. I think I used a 3/16" bit, but eyeball the thick end of the rivet and see:
Ford Bronco Sport Installing front license plate holder PXL_20210529_142846311
The bumper is really thin where the mount goes, so be careful not to push too hard when drilling.
Ford Bronco Sport Installing front license plate holder PXL_20210529_143046824
The thick end of the rivet goes in, and the nail sticks out:
Ford Bronco Sport Installing front license plate holder PXL_20210529_143255753
Put the rivet gun on the nail and pump the handle a few times until the rivet flattens and the nail pops out.
Ford Bronco Sport Installing front license plate holder PXL_20210529_143502253
Finish all three and you're good to go!
Ford Bronco Sport Installing front license plate holder PXL_20210529_143544824
I'm probably the only one who 1) didn't have a dealer who would install it, and 2) had never seen a pop rivet before, but I was a bit baffled by the whole thing and lack of instructions. Hopefully this helps someone, anyway#
RS1
Ralph
Boston
So many lazy dealers. Cannot pop rivet license plate holder on? They sent you away driving illegally with no front plate. Another dealer can’t trim to fit mud flap/splash guards to go on with fender flares?
Fossil
Ernie
ohio
your dealer sucks
DISCOLEG
Looks good, good job
Sandman
Scott
MI
21 Ford Bronco Sport
If anybody has a front license plate mount they don't need. I am a volunteer FF/EMT need to add my station tag on front. My dealer does not have any
Dedbolt
Keith
NM
2022 BS, 2013 Harley Switchback
I took off my plate holder off the front. Didnt want it installed as I live in a state that doesn't require a front plate...and the dealer put it on crooked. It bugged me and had a plate from the dealership on it. Your welcome to it.
Mascot1978
Bev
Don't feel bad....I spent 2 hrs on the front plate last night trying to get screw to stay in because the pre-drilled holes in bumper were either stripped, or I did it trying to simply mount a front plate which i have done a thousand times!!! Anyone know what I can do to make bolts stay in holes? Can't put nut on back of screw. Didn't get rivets. I did not attempt to do back plates....too aggravated?
Reklussloth
Colton
2021 bronco sport
Go to a bigger screw.....
Move it over 1/4 in...
Use a self adehesive tape on the contact spots like 3m
Fill holes with a sealant and do it again ..
Remove bumper and sue a bolt and nut.
tahpasohej
New Jersey
2021 Ford Bronco Sport Badlands Edition
jofer, thanks for your post. I was able to find the stock front license plate at the dealer. The cost was about $33 after sales tax.
The part number is:
M1PZ17A385AA
This link shows the part on a diagram: Ford OE M1PZ17A385AA - Front License Plate Bracket (carid.com)
Your help eliminated any surprises (rivet gun) and the end result looked like it was installed at the assembly plant.
My dealer wanted me to come back later to get plate installed. But I saw this thread and did it myself to save a trip back to dealer.
Tip: there are two small dimples in the front bumper for the two upper rivet holes. So if you drill where the dimples are it will be placed perfectly. I drilled the two upper holes first, put rivets in, then drilled the one lower hole last.
Robins21
Horse Pasture, Virginia
Our BS/BB did not come with one, & it is not listed on the window sticker. I got one from a nearby dealer & installed in a couple minutes using screws.
BenOutside85
Ben
Alaska
Honda civic, Subaru Outback
Mine came with having to do it myself too. This really helped as I too had not used a rivet gun before. Thanks so much for clear pics and instructions!
rkym
Brian
sport0210$
2021 Bronco sport
Any one have a front license bracket for sale? i'm in need of one
Thank you
