Auto start a little kick in the pants
Backpackster
Jeff
Ottawa Ontario
2021 Ford Bronco
I have autostart on both my 2017 F-150 and my bs bb. On the bronco, it feels like a subtle kick in the pants. First time it happened I had to look in the rear view mirror. The F-150 is silky soft. Has anyone else noticed this or is it the way it is.
Area51
North Dakota
’21 Badlands, ’08 Ranger 4x4, ’16 Focus ST
I wonder if it's because it's because of the cylinder count, three or four compared to six or eight. The first couple times our 2.0L Badlands auto-started it surprised me with its little shudder as it started. The first time it shut down I thought the engine had died—well, it had, but on purpose. I've only driven the Badlands two or three times so far but I think I'll get used to that.
Ponds
SE MI
You’ll get to the point where you don’t notice it at all. Well, at least with a 2017 Escape I’ve had for over 3 years. It was my biggest concern before buying it and hasn’t caused any issues. I’d bet that it’ll be the same for my BS once I finally take delivery.
Area51
North Dakota
I think you're right, having driven it more today I hardly notice it now.
wilbur_xmas
Will
Bay Area, CA
Ours gives a kick in the pants for sure, feels like it tries to jump forward a bit. This only happens when stopped at a light long enough that the engine restarts while still fully stopped and foot firm on the brake. In other circumstances when you are lifting off the brake it is very subtle.
Midgiesbronco
Connecticut
There’s a button on the dash to turn auto start off and on...
Yeah but this way no turning it off every time you start it. It's my wife's whip, she hates the auto start/stop but I don't see her remembering to disable it every start
WoodmanMN
Woody
WAAAAAAAAAAAY Up North
If you have a trailer kit, all you need is a trailer light tester plugged in to make the BCM think there is a trailer attached. That disables the auto-stop/start too.
having mine through the weekend, I sincerely can't tell 99% of the time when it stops and starts. My wife's jeep, it's as described in the OP, jerky and somewhat annoying. My sport, I can't tell. It's smooth and maybe as I drive in eco most of the time, maybe that's a contributing factor?
Mellow
Carrollton, TX
2019 Ranger/2012 Miata
Hi all. I currently have a 2019 Ranger w/Auto Start/Stop.
I hate it... lol.. so, I read in the manual it would be disabled if you plugged in a laptop to charge via the 110 outlet. So, I decided to try an LED nightlight and that did the trick. Not all of them will work so it took me 2 or 3 before I found one that worked and wasn't too noticeable from the cabin area... however, with the BS you have the one in the rear cargo area, perhaps that will have the same results?
Evantually, I decided to use Forscan and turn it off permanently.
Mellow
Carrollton, TX
Here we go, similar text in the Ranger manual:
Any of the following conditions could result in an automatic restart of the engine if:
  • The blower fan speed increases or the climate control temperature changes.
  • You plug in or switch on an electrical accessory.
MoFoCo
Mayor's Income, TN
Barely notice the A-S-S system in my BL. It is annoying when you pull into a parking space and it stops, then starts again when you shift to park, then stops a second later when you switch off the ignition. Seems like unnecessary wear and tear added.
a33maxi
New England
2021 Bronco Sport - sold
You can get around this by just hitting the engine stop button, it will automatically shift into park for you.
