Latest Bronco Sport Order Guide, dated 11/01/20.
I test drove a BL(no BL package) and it had a rear camera.I'm still confused about what trim levels include a rear camera with washer? Best I can tell the Badlands with Badlands doesn't include the rear washer on the camera. I'm not sure which trims have the rear washer. Can anyone confirm or deny?
I'm guessing that the have plumbing/pump for one camera and opted to put it on the front camera on the Badlands. Day to day I think I might have found it more useful in the rear.
I'm seriously thinking about seeing if I can change my order to remove the moonroof on the Badlands with Badlands package. May 17th project build at the moment.
Didn't know that was an option.I'm seriously thinking about seeing if I can change my order to remove the moonroof on the Badlands with Badlands package. May 17th project build at the moment.
Thanks but I believe all Bronco Sports have rear cameras, it's the camera washer that isn't on all of them and isn't clear.I test drove a BL(no BL package) and it had a rear camera.
Looks like your right. The new order guide indicate that they've add the option on Big Bend and Outer banks to delete the moon roof from but not the Badlands, my bad. I'd much rather have the higher dynamic rack limit than the moon roof.Didn't know that was an option.
Thanks.Looks like your right. The new order guide indicate that they've add the option on Big Bend and Outer banks to delete the moon roof from but not the Badlands, my bad. I'd much rather have the higher dynamic rack limit than the moon roof.
Lower trims had a standard 12V power point in the center arm rest console instead of the two USB connections. And I can’t find it now but recall there was a slight difference in the center stack console power as well. Sounds like they are making it more a standard feature.Thanks.You said Badlands originally. That above mentions Outer Banks only.Didn't fully ready your reply there.
Wonder what's that "Updated USB Ports" item is all about.
Beginning in May 2018, all new vehicles sold in the United States are required to have rear cameras.Thanks but I believe all Bronco Sports have rear cameras, it's the camera washer that isn't on all of them and isn't clear.
Ford website advertises the "available" built-in washer for the rear camera. What an oversight on the Badlands -- wow, that sux! Has to be true, read here somewhere (?) disappointment how the rear cam gets dirty quickly. Not an exotic option at all, many makers have it, how you admit it on the Badlands I just don't understand.Beginning in May 2018, all new vehicles sold in the United States are required to have rear cameras.
As for the washer, Badlands only has it on the front camera. It looks like they are adding it to Big Bend and Outer Banks.
