Bdub
Bryan
MD
F150
Thanks for posting @Ponds. It looks like Ford clarified a few things including the CoPilot Assist 2.0 vs plus.
Huntyeraws
Nick
Rochester, NY
2021 Ford BS BB
So it looks like you now can get a BB package without the moonroof.
pixlpush
Portland, OR
I'm still confused about what trim levels include a rear camera with washer? Best I can tell the Badlands with Badlands doesn't include the rear washer on the camera. I'm not sure which trims have the rear washer. Can anyone confirm or deny?
I'm guessing that the have plumbing/pump for one camera and opted to put it on the front camera on the Badlands. Day to day I think I might have found it more useful in the rear.
I'm seriously thinking about seeing if I can change my order to remove the moonroof on the Badlands with Badlands package. May 17th project build at the moment.
5Dogs
Toni
Ford Escape
I test drove a BL(no BL package) and it had a rear camera.
SM05
West Virginia
Didn't know that was an option.
pixlpush
Portland, OR
Thanks but I believe all Bronco Sports have rear cameras, it's the camera washer that isn't on all of them and isn't clear.
pixlpush
Portland, OR
Looks like your right. The new order guide indicate that they've add the option on Big Bend and Outer banks to delete the moon roof from but not the Badlands, my bad. I'd much rather have the higher dynamic rack limit than the moon roof.
Ford Bronco Sport 2021 Bronco Sport Order Guide! (Options, Packages, Equipment, Accessories Revealed) - U.S. & CANADA no-moon-roof
SM05
West Virginia
Thanks. You said Badlands originally. That above mentions Outer Banks only. Didn't fully ready your reply there.
Wonder what's that "Updated USB Ports" item is all about.
CanineChamp
Lionel
Denver, CO, United States
Mork
I have a FE, but test drove a launch BL+BL. It did not have a rear camera washer. Must be new.
Shiskamba
Tennessee
2015 Ford Focus SE Hatch
Lower trims had a standard 12V power point in the center arm rest console instead of the two USB connections. And I can’t find it now but recall there was a slight difference in the center stack console power as well. Sounds like they are making it more a standard feature.
MiHusker
Dexter, Michigan
Fusion Energi, Bronco Sport Outer Banks
Beginning in May 2018, all new vehicles sold in the United States are required to have rear cameras.
As for the washer, Badlands only has it on the front camera. It looks like they are adding it to Big Bend and Outer Banks. It lists it as standard on the Big Bend and all standard items from there are on the Outer Banks. Given that the Badlands also states "INCLUDES ALL BIG BEND™ STANDARD EQUIPMENT PLUS: ", I would suspect that it would be on there too.
Ford Bronco Sport 2021 Bronco Sport Order Guide! (Options, Packages, Equipment, Accessories Revealed) - U.S. & CANADA 1614540416786
tRex
Rochester, NY
Reading the 2/27 Guide very closely, it looks like all builds after 5/10/21 are getting a few more of the little features that were only on th OB/BB/FE before. Nice...(ex. new USB ports inside/back of center console; BB/OB get the rear camera washer; BB gets speed signs and adaptive cruise added to the BB Assist+ pkg.;
Ford website advertises the "available" built-in washer for the rear camera. What an oversight on the Badlands -- wow, that sux! Has to be true, read here somewhere (?) disappointment how the rear cam gets dirty quickly. Not an exotic option at all, many makers have it, how you admit it on the Badlands I just don't understand.
Bdub
Bryan
MD
F150
Just like the FE didn't have Copilot 360 Assist +......
