- Thread starter
- #1
You're about to fill up your gas tank for the first time in your Bronco Sport.....will you be using 87 or 91 octane?
I agree. The reason higher octane fuels might offer higher horsepower has nothing to do with energy density, rather advanced timing. If an engine runs well with 87 octane in your environment (e.g. temperature, altitude) and your timing is not being retarded, then it is the better choice. The Mazda SkyActiv engines are somewhat high compression and Mazda's recommendations are similar (87 OK, but 91 optimal for max performance). I did extensive testing with my CX-5 over at least ten thousand miles. I couldn't tell any difference in performance and the economy with the 87 is far superior.Why would anyone think a higher anti knock formula fuel would be beneficial ?
My 1.5 doesn't knock or ping at all, the engine is designed to run on 87 so why defeat the monetary savings of the 26 mpg with a far more expensive fuel ?
This is correct. In modern cars it will not hurt your engine to run lower octane (87) but a higher octane allows your engine to tune itself for more power. I think it’s probably best to be consistent in whatever you choose, because it takes some time to adjust.I agree. The reason higher octane fuels might offer higher horsepower has nothing to do with energy density, rather advanced timing. If an engine runs well with 87 octane in your environment (e.g. temperature, altitude) and your timing is not being retarded, then it is the better choice. The Mazda SkyActiv engines are somewhat high compression and Mazda's recommendations are similar (87 OK, but 91 optimal for max performance). I did extensive testing with my CX-5 over at least ten thousand miles. I couldn't tell any difference in performance and the economy with the 87 is far superior.
Any gas with ethanol will not hold up for long. Learned that over the years from dirt bikes. You get about three months out of gas with ethanol before it starts to turn.And if your car sits longer between fill ups the premium should hold up better and not degrade as quickly, correct? It’s also better for the longevity of the turbo (From what I’ve read). Not an expert by any means.
Thanks for the insight, Excape. Just brought home my wife's 2021 CX-9 yesterday and haven't done any break-in or driving in it yet...but of course was excited about the prospect of 250-hp versus 227-hp on premium fuel vs regular. If you are not noticing any measurable "head thrown back" excitement in your CX-5 by rolling with premium, then I will save the money too and stick with 87 on both the Mazda and my future Baby Bronc.I agree. The reason higher octane fuels might offer higher horsepower has nothing to do with energy density, rather advanced timing. If an engine runs well with 87 octane in your environment (e.g. temperature, altitude) and your timing is not being retarded, then it is the better choice. The Mazda SkyActiv engines are somewhat high compression and Mazda's recommendations are similar (87 OK, but 91 optimal for max performance). I did extensive testing with my CX-5 over at least ten thousand miles. I couldn't tell any difference in performance and the economy with the 87 is far superior.
Well, results may vary depending on your altitude, temperature, regional fuel blend, and probably many other factors. But in my case, the "butt dynometer" didn't record any discernible difference.Thanks for the insight, Excape. Just brought home my wife's 2021 CX-9 yesterday and haven't done any break-in or driving in it yet...but of course was excited about the prospect of 250-hp versus 227-hp on premium fuel vs regular. If you are not noticing any measurable "head thrown back" excitement in your CX-5 by rolling with premium, then I will save the money too and stick with 87 on both the Mazda and my future Baby Bronc.
Yeah I read that but I doubt I'll ever push my engine into that upper zone of 90-95% power.87 is required. 91+ is recommended (for max targeted hp) and other times for best overall vehicle and engine performance.
ExactlyI’ve “trained” all of my car’s computers to use low octane, even my Porsche Boxter. Never had an issue and see no reason to change now.
