Not yet in CanI wonder if Canada doesn't require them?
Not sure, but I can try and find out tomorrow.AFAIK, it was:
a) only CARB-compliant state deliveries, and
b) started with MY 2025 1.5L Job 2 builds (sometime last January?) and MY2025 2.0L Job 3 builds (late June last year).
@rugedraw may have better insight.
Gas Particulate Filter.Excuse me for asking but what is a GPF?
I dug through OASIS, but was not able to find any concrete info on this. From what I gather, Ford had supply chain issues with the GPF and many vehicles that were supposed to have it were built without it; even if they were designated for CARB states.AFAIK, it was:
Thank you for taking a look at this. I suspected it wasn’t quite cut and dried. The early supply chain theory sounds plausible. I’ll DM you my VIN so you can take a look at one that is known to have a GPF.…I would need the VIN of a vehicle that has one so I can dig through the build codes….
Got your message. Your car shows the same build code there:Thank you for taking a look at this. I suspected it wasn’t quite cut and dried. The early supply chain theory sounds plausible. I’ll DM you my VIN so you can take a look at one that is known to have a GPF.
Thank youGas Particulate Filter.
After a little more detective work, I'm pretty sure I can determine if a vehicle has a GPF or not based on a picture of the VECI label.I think you can look at the cert label on the underside of the hood and tell. If someone with a GPF posts a pic of theirs, I can confirm.
Here's an example.
Genius, and no special access to anything is needed.After a little more detective work, I'm pretty sure I can determine if a vehicle has a GPF or not based on a picture of the VECI label.
This is from one of the 25MY Bronco Sport test groups.
Exactly.Genius, and no special access to anything is needed.
Ok here's the VECI from my 2025 with a GPF on it, what do you think?After a little more detective work, I'm pretty sure I can determine if a vehicle has a GPF or not based on a picture of the VECI label.
Thanks for posting!Ok here's the VECI from my 2025 with a GPF on it, what do you think?
