Bronco ForScan Thread
hefler
Global
Bronco Sport 2023
I messed around with it a bit more, but couldn't get it to do anything. I'm not ready to give up on it. Can you message me the VIN of this truck that has it working?
I will try to get it but the guy is the paranoid type in provinding info.
rugedraw
Javier
Miami, FL
Or the VIN of anyone with a 21-24 that has working power-fold mirrors. I would like to compare the part numbers and a/b data to mine.
hefler
Global
Bronco Sport 2023
fold automatically or the one that you just need to press the button?
rugedraw
Javier
Miami, FL
Any of the two. If the mirrors fold in electronically, it can be configured to do either or.
Another wildtrak with power fold mirrors, didn’t post a VIN# and looks like hasn’t been on since 2022​
Hmm. Second instance I've seen of a Brazil BS that has it. Let me see if I can find a BS for sale in Brazil.
First one I found and it has the button for power-fold mirrors on the window switch but no VIN. Seems like Brazil spec vehicles hold the key.
https://www.webmotors.com.br/comprar/ford/bronco-sport/20-ecoboost-gasolina-wildtrak-4x4-selectshift/4-portas/2023/60370488
fcesarbr
Francisco
Brazil
BRONCO SPORT (WILDTRACK) 2024
Hello, I’m new here and I’m also trying to get the automatic mirror folding to work. I have a 2024 BS Wildtrack with electric mirror folding, but it only works by pressing a button. If you want, I can send you the VIN number in a private message.
rugedraw
Javier
Miami, FL
Yes please!
Edit: Actually, I already have the VIN of a vehicle that has the same functionality as yours. I would need one where they do fold automatically so I can compare the as-built data of the door modules to see what is different.
rugedraw
Javier
Miami, FL
@hefler @fcesarbr
I have something you guys can try:
Ford Bronco Sport Bronco ForScan Thread 1755025816611-9t
Try changing this value in both the driver and passenger door modules to a 1. Hefler's truck already has power fold enabled from factory as per my post #319. However, Lincoln auto-fold is disabled on his truck. Lincoln auto-fold will only unfold mirrors when the driver's door is opened & shut or the engine started (whichever comes first). This MAY be the only way to get it to work on these cars. One of you would have to try it to see what happens.
rugedraw
Javier
Miami, FL
@hefler @fcesarbr
Never mind.....based on the VIN @hefler just sent me of the BS that does have it working, that truck shows Lincoln auto-fold as disabled. I will compare the ab data to see if I can spot the difference(s).
rugedraw
Javier
Miami, FL
@hefler I am stumped. I have checked every line in the door modules of the VIN you sent me compared to yours and everything is a perfect match.
fcesarbr
Francisco
Brazil
Yes please!
Certainly, you are comparing AsBuilt data downloaded from Ford using the VIN. This vehicle must have been modified using some paid solution. Here in Brazil, for example, we have a company called Faaftech, which sells an OBD2/Bluetooth device they call “Custom Easy,” which works together with an app also called CustomEasy. This application can be downloaded for free from app stores, but it requires the purchase of credits to function.
It would be necessary to connect Forscan to this friend’s vehicle from @hefler and download the data directly from the vehicle.
In short, the guy in the video says he programmed the window roll-up and mirror folding functions using the “Custom Easy.”
rugedraw
Javier
Miami, FL
If that is the case and it was custom programmed, then you are correct. We would need to plug into the vehicle directly to get the correct ab data off the truck.
hefler
Global
Bronco Sport 2023
If that is the case and it was custom programmed, then you are correct. We would need to plug into the vehicle directly to get the correct ab data of the truck.
I will do that Saturday
For 2023 there is no such option in this application.
fcesarbr
Francisco
Brazil
Update:
I installed the app and was able to see what customizations would be available. There’s nothing related to mirrors. In fact, there are fewer options than what we already have here on the forum. There are options related to opening/closing windows and some things regarding headlights and turn signals. There’s not even an option to disable auto start/stop. I believe the vehicle shown in that video has some kind of hardware/wiring solution.
