kenmitch
Ken
SoCal
2025 BS
I would double check the fitment of those the correct model is an RX 100 for the bronco sport. I believe I ordered the ones you did and they did not fully seat. Called Rhino-Rack direct and they told me yes there are a lot of people selling the wrong model numbers. Just glancing at the information you provided it does not look correct. They should be about $399 MSRP.
I was actually looking at the Pioneer Platform on Rhino's website and looked for crossbars for my vehicle. Once I found them I then googled the Rhino part number and found them on Summits website.
Ford Bronco Sport What did you do TO your Bronco Sport today? Crossbars_kit
The above is the kit contents from Rhino's website so they should work as Summit is showing the same Rhino part number.....I guess I'll see Monday or Tuesday.
UPS shows Tuesday delivery, package details say 13 lbs. so it should be all the above.
EDIT....All of the above items were delivered on Wednesday. Shows they have a few more in stock if anybody is looking for crossbars or even the legs for that matter.
kshaw
Kent
Gaithersburg, MD
I recently ordered an Ancel Battery Monitor BM300 Pro for my Porsche and liked it so well that I ordered two more for the BS and my 350Z. It provides battery status on your phone and will even send you notifications if anything needs your attention. In addition to current voltage and state of charge, it shows your cars current location. Installation is easy and it just attaches to your positive and negative battery posts.
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_4371
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_4372
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_4373
Put on a fordrangerlifts 1.75in lift; worked out great!!! Looks awesome without making the car look stupid lifted, adds a lot of functional clearance, especially on that front lip. Surprised at just how much larger it feels. Still needs an alignment. This is on 235’s
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_5153
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_5168
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_5169
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_5171
I did a bell tech lift on mine and put 235/70/17 Goodyear tiresRides great..
I’ll find out shortly. I only have the spare right now as it’s 245/65R17, the largest size I could fit inside the Sport (still had to remove the insulation padding, and must “fiddle“ with the hold down rod). I’m waiting for delivery of the “on-the-ground” tires which will be 235/70R17’s.
I did a bell tech lift and put on 235/70/17 ; rides great; what lights did you stick in the grill ?
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_1289
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_0417
kenmitch
Ken
SoCal
2025 BS
The complete kit was delivered on Wednesday which included the 2 rails and 4 RX 100 legs. Are you using this setup? If so do I have to mount the legs at the stock mounting spots? Or can I mount the rails at a location of my choice as long as the outer claw does the wrap around?
Putter Boy
Jonathan-Boyd
Pinehurst, N.C. 28374
I would call Rhino-Rack and get their technical support. I had a few other questions. They answered very quickly for me on the phone. They’re based in Colorado and here’s the number. 1 (877) 744-6622
2025 Badlands Sasquatch
Busy day yesterday. Added:
  • LED Brake Lights. The reverse lights didn't fit, going back.
  • Retracting Rear Cargo Cover. I have the CMS, but it's pretty limiting for daily use since it lowers the covered area to 9" depth. It'll be better suited for off-roading, camping, etc. for layered cargo storage.
  • Eclipse Sunshade. I love these things, but recommend holding off for now. The only one they sell for the BS says 21-25, but I don't think they actually measured the '25 model year. I've got a ticket in with them now.
@jkernitzki why do you think the windscreen would be any different on a 2025? (Im assuming this is a sunshade for the windscreen)
The sensor package on the ‘25’s (or at least Badlands Sasquatch) is huge. It was obvious they didn’t properly account for the dimensions.
…probably go knock off on the cargo area as the Ford one is pricey!
Did you check the discounted Ford internet sites for the Ford cargo mat? Especially when you live within driving distance of one that allows pickup to skip the shipping charge which likely is high for the Ford cargo mat.
