- Joined
- Aug 20, 2023
- Threads
- 1
- Messages
- 30
- Reaction score
- 83
- Location
- California
- Vehicle(s)
- 2023 Ford Bronco Sport
Installed EGR in-Channel Window Visors; Front and Rear; Matte Black.
Do you have a link for that?Installed EGR in-Channel Window Visors; Front and Rear; Matte Black.
it looks like you just ordered the cross bars. You also required to order the feet which are in the photo below bringing the total to around $500 which would be right.I would double check the fitment of those the correct model is an RX 100 for the bronco sport. I believe I ordered the ones you did and they did not fully seat. Called Rhino-Rack direct and they told me yes there are a lot of people selling the wrong model numbers. Just glancing at the information you provided it does not look correct. They should be about $399 MSRP.
I was actually looking at the Pioneer Platform on Rhino's website and looked for crossbars for my vehicle. Once I found them I then googled the Rhino part number and found them on Summits website.I would double check the fitment of those the correct model is an RX 100 for the bronco sport. I believe I ordered the ones you did and they did not fully seat. Called Rhino-Rack direct and they told me yes there are a lot of people selling the wrong model numbers. Just glancing at the information you provided it does not look correct. They should be about $399 MSRP.
I did a bell tech lift on mine and put 235/70/17 Goodyear tiresRides great..Put on a fordrangerlifts 1.75in lift; worked out great!!! Looks awesome without making the car look stupid lifted, adds a lot of functional clearance, especially on that front lip. Surprised at just how much larger it feels. Still needs an alignment. This is on 235’s
I did a bell tech lift and put on 235/70/17 ; rides great; what lights did you stick in the grill ?I’ll find out shortly. I only have the spare right now as it’s 245/65R17, the largest size I could fit inside the Sport (still had to remove the insulation padding, and must “fiddle“ with the hold down rod). I’m waiting for delivery of the “on-the-ground” tires which will be 235/70R17’s.
The complete kit was delivered on Wednesday which included the 2 rails and 4 RX 100 legs. Are you using this setup? If so do I have to mount the legs at the stock mounting spots? Or can I mount the rails at a location of my choice as long as the outer claw does the wrap around?I would double check the fitment of those the correct model is an RX 100 for the bronco sport. I believe I ordered the ones you did and they did not fully seat. Called Rhino-Rack direct and they told me yes there are a lot of people selling the wrong model numbers. Just glancing at the information you provided it does not look correct. They should be about $399 MSRP.
