rorlow
Ron
Detroit MI
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_2203
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_2207
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_2206
This is what I got from Etsy as a replacement from a replacement order for the first one that was bad.
Etsy Trash Vendors
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_7583
Check out Underground Graphics, I got mine from there and no wrinkles/crinkles, quality and fast delivery.
Yep, along with a touch of off-roadiness.
I've felt you can't see much, if any difference from 225 to 235. Your look is different. Add tire shine and the tires may look even bigger.
Ford Battery Recall 25S02 done. I'll take 4 more years of battery life! Fairly smooth process except my dealer was not willing to do the remote service because they don't want to do programming that way (the charging system recall). Figured if I get one, get both. Tech failed to replace the red cap on the positive battery terminal. Minor, but this is why I have to check their work and why I don't like going in for service. Could just as easily failed to tighten the posts.
Like, check out my new labels. You mean to tell me that some fancy label machine isn't doing that labor? Was label guy drunk at work on Tuesday?
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_20250801_140519311
hdiego05
Los Angeles
Bronco Sport Badlands
Installed ARB Single Air Compressor under the hood. I am using a mount that my friend and I created. It's completely bolt-on. The hard part was running the wires through the passenger grommet. Cheers!
Ford Bronco Sport What did you do TO your Bronco Sport today? 1754093143752-x9
Rob Binsky
the West
2025 Bronco Sport, 2023 full-size Bronco Wildtrak Sasquatch
The black trim on the wheels, to me, makes the tires look bigger. Very nice!
That black trim - is it part of the wheels, or did you buy that separate?
Rob Binsky
the West
Quashish
Tomas
Sacramento
2024 Bronco Sport Badlands
Installed a K&N drop in filter and VTA mod yesterday to go along with the Livernois tune. Also ordered some LED front and rear bumper reflectors, LED fender side markers and as well LED bulbs for the reverse lights that look yellowish when they light up. After reading @Putter Boy comment, seems like I may need to return them and get ones with the resistor.
What's the vent to atmosphere mod for these cars? Did you just replace the bypass valve with a blowoff?
rugedraw
Javier
Miami, FL
Nah, I just plugged the line. I did the same mod to my F150 a few years ago. I found this video on YouTube (fast forward to 8:45 to skip past the blah blah blah):
I didn't like the Home Depot fix that he used to plug up the return line, so I used the same billet aluminum plug that I used for my F150 and it worked perfectly using the OEM clamp that the vehicle came with:
https://www.amazon.com/dp/B0DCBK5N27?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
