Ford Battery Recall 25S02 done. I'll take 4 more years of battery life! Fairly smooth process except my dealer was not willing to do the remote service because they don't want to do programming that way (the charging system recall). Figured if I get one, get both. Tech failed to replace the red cap on the positive battery terminal. Minor, but this is why I have to check their work and why I don't like going in for service. Could just as easily failed to tighten the posts.
Like, check out my new labels. You mean to tell me that some fancy label machine isn't doing that labor? Was label guy drunk at work on Tuesday?
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_20250801_140519311
hdiego05
Los Angeles
Bronco Sport Badlands
Installed ARB Single Air Compressor under the hood. I am using a mount that my friend and I created. It's completely bolt-on. The hard part was running the wires through the passenger grommet. Cheers!
Ford Bronco Sport What did you do TO your Bronco Sport today? 1754093143752-x9
Rob Binsky
the West
2025 Bronco Sport, 2023 full-size Bronco Wildtrak Sasquatch
The black trim on the wheels, to me, makes the tires look bigger. Very nice!
That black trim - is it part of the wheels, or did you buy that separate?
Rob Binsky
the West
Quashish
Tomas
Sacramento
2024 Bronco Sport Badlands
Installed a K&N drop in filter and VTA mod yesterday to go along with the Livernois tune. Also ordered some LED front and rear bumper reflectors, LED fender side markers and as well LED bulbs for the reverse lights that look yellowish when they light up. After reading @Putter Boy comment, seems like I may need to return them and get ones with the resistor.
What's the vent to atmosphere mod for these cars? Did you just replace the bypass valve with a blowoff?
rugedraw
Javier
Miami, FL
Nah, I just plugged the line. I did the same mod to my F150 a few years ago. I found this video on YouTube (fast forward to 8:45 to skip past the blah blah blah):
I didn't like the Home Depot fix that he used to plug up the return line, so I used the same billet aluminum plug that I used for my F150 and it worked perfectly using the OEM clamp that the vehicle came with:
https://www.amazon.com/dp/B0DCBK5N27?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
kenmitch
Ken
SoCal
2025 BS
I ordered some crossbars from Summit Racing this AM. I might go with the Pioneer Platform and I'll need the legs that come with the crossbars anyways. I'm not sure why the legs cost more than the kit?
Ford Bronco Sport What did you do TO your Bronco Sport today? Crossbars
Putter Boy
Jonathan-Boyd
Pinehurst, N.C. 28374
I would double check the fitment of those the correct model is an RX 100 for the bronco sport. I believe I ordered the ones you did and they did not fully seat. Called Rhino-Rack direct and they told me yes there are a lot of people selling the wrong model numbers. Just glancing at the information you provided it does not look correct. They should be about $399 MSRP.
Putter Boy
Jonathan-Boyd
it looks like you just ordered the cross bars. You also required to order the feet which are in the photo below bringing the total to around $500 which would be right.
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_2361
