Wheel bolt pattern the same for all 2021 > 2025 Bronco Sports ??
TrueNorthSport
Martin
Toronto,Ontario,Canada
Just picked up my new 2025 BS BB last week and as many of you know , it came with a 12V tire pump but without a spare tire, jack or lug wrench. The Ford dealer wanted about $700 to $800 (Can) to supply a mini - spare rim, tire and jack hardware ! A local tire shop suggested I try to find a mini - spare and hardware from an auto recycler.
My question for the forum > Is the bolt pattern the same for all Bronco Sports ('21 to '25) ? This would help in locating these items .
Many thanks
Many thanks
You can find mini spares by the handfuls on EBay for 100-150. I replaced my full size spare with the same rim and tire so I could rotate it with my normal rotations. The spares should come with the TPMS as well. Looks like some come with the jack as well.
RidingTheBronco
JOHN
ca
I got my mini spare on eBay, also. $99 with a jack. The bolts line up visually. I have not tried it on yet. Of course, this is a piece of mind thing. The only spares I have ever used were on vehicles in the over-20-year-old club. Also, if you live in a place like Hawaii, you should be changing your tires every 6 years, regardless of wear due to sun rot. Honestly, I do not expect to ever need this spare. But if I do, I should be able to make it to a shop.
TrueNorthSport
Martin
TrueNorthSport
Martin
Thank you sir, you have saved me hundreds of $$$ on a spare tire !
So Ford supplied my new BS with a tire inflator and sealant but in the "Supplemental Owners Guide" that came with the car it says "The use of tire sealants can damage the tire pressure monitoring system " !!
I think I will order a mini spare and jack hardware ASAP !
Cheers
Unicorn
Chester
W. WA
BS Badlands with Sasquatch.
If you're going to get a spare, why not try and find a full size wheel? Check ebay and junkyards. It's likely that some will have a few.
RidingTheBronco
JOHN
ca
If you're going to get a spare, why not try and find a full size wheel? Check eBay and junkyards. It's likely that some will have a few.
The size. A full spare will push that thin wheel cover in the back way up. Otherwise, you have to mount it outside. That seemed awkward, too.
Unicorn
Chester
W. WA
Won't the 225/60-R17 tire and wheel fit wit the thin cargo cover?
Full size fits fine in the well. The cargo mat goes in the higher position. Also, I had to make a 3D printed nut to hold the wheel down.
Ford Bronco Sport Wheel bolt pattern the same for all 2021 >  2025 Bronco Sports  ?? IMG_3339
TrueNorthSport
Martin
