BL Sasquatch AUX Switches Wiring Guide?
ELCouz
Canuckistan
I am curious if Ford has detailed electrical plan for the four AUX switches?
I am planning to receive the sasquatch soon, just to know what I can install on each...
Bluebaru
2025 Badlands Sasquatch
So this is very similar to the full size. It pre-runs wires to the back, front bumper, front cowl, and A pillar.
Not to the back, unfortunately. Bumper, roof, left & right cowl.
You are correct. My picture understanding skills are beginning to diminish!
I just wish there were circuits running to the rear as well.
ELCouz
Canuckistan
Hmmm I am installing the lights... I can't find a single one of them ... anyone with a sasquatch can point them with a real picture?
I am trying to find A (AUX1) for the front led bar I can't find that dandling wire in spot A...
Is that spot inside the firewall ? If so that would suck hard
ELCouz
Canuckistan
Ford Bronco Sport BL Sasquatch AUX Switches Wiring Guide? 2025-04-27 15_06_21-2025_Ford_Bronco_Sport_OM_ENGLISH_V1.pdf - Adobe Acrobat Reader (64-bit)
Ford Bronco Sport BL Sasquatch AUX Switches Wiring Guide? RnrCU5R
I don't see anything there looks like Spot A
ELCouz
Canuckistan
Did you pop off the liner?
There is a post on this forum with specific instructions
what liner? inside? wheel fender liners?
I'll try to find the post ?
ELCouz
Canuckistan
oh the bronco nation one
Finding these weren’t so easy. D is located in the engine bay as expected but A-C are actually located in the wheel well behind the liner. The diagram without any explanation was challenging on my part, I spent some time searching and hoping that it was not where it turned out to be. To a lesser extent, Ford substituted letters for the auxiliary numbers, but our assumption was A=Aux 1, etc.
Our liner is plastic, and we were able to remove a couple of the securing clips and by carefully folding it back to expose the wires, we did not have to completely remove the liner but we did have to remove both front tires. (Use jack stands and extreme caution when working in this area!) After completing the connection, we were easily able to pass the wires up and into the engine bay to connect to the battery.
dang I passed through that text a while ago oops... also wheel wells why ?!!? ?
hcrews1955
Hilton
Purlear, NC
I took my BS BL Sasquatch to my Ford Dealer and let the tech run the wires. Then I hooked them to a terminal block and attached my Diode Dynamics amber fog lights and for future options.
Ford Bronco Sport BL Sasquatch AUX Switches Wiring Guide? Diode Dynamics pods and bar
