Towing Capacity..... What's your Minimum.? 2000 LBS? 3000 LBS? More?
The Pope
NC
1977 F250/2007 Mercury Mariner/2014 Infiniti Q60x/2011 Kawasaki C14
My 2007 Mercury Mariner is factory rated for a Max of 3501 LBS., so for me, that's my minimum for the Sport.
Just for a reference... the Honda Pilot & Passport AWD's are rated for 5000 LBS., so to be competitive with what I "think" will be a similar sized competitor, hopefully the Sport will have a similar rating.
FirstOnRaceDay
Devin
Toledo Ohio
2000 Mercury Grand Marquis, 2017 Honda Civic, 2019.5 Chevy Silverado
Jeep Cherokee is also 4500lbs with its towing package. So yes I think 5000lbs SHOULD be the ball park for the towing package. I’ll be OK with 4000 but I think ford needs to be very aggressive in its towing abilities
however the C2 platform cousin Escape only has a max of 3500 as does the Edge.
Explorer has 5600 but that’s with its 400lbft motor.
Motorpsychology
Chris
Prescott, Wisconsin
'18 Ford Escape, '09 Mercury Mariner, '17 Suzuki V-Strom 650, '80 Kawasaki KZ750 (Bought new)
Apples to apples, would be the Honda CR-V: 1500lbs, I think the CVT trans is probably the limiting factor. 5 X 8 single axle trailer for towing an ADV & dual sport bikes- 1800lb towing is fine fo me.
FirstOnRaceDay
Devin
Toledo Ohio
Most of the smaller SUVs have CVT or just a really weak <2.0L motor.
but yes most only have 1500-2000lb of towing. But some like the Cherokee pushes 4000lb I think ford definitely needs to fit in there some where over 3000 under 4500
Motorpsychology
Chris
Prescott, Wisconsin
I would guess the Sport, being derived from the C2 Escape platform, will have a slightly less than 3500 lb towing, slightly more GCWR, owing (hopefully) to heavier "built very rugged" vehicle components.
Bertman
Bert
Denver
2012 VW Jetta Sportwagon TDI, 1972 VW Super Beetle, Suzuki Burgman
I don’t plan to tow anything, but I would like a factory installed 2” rear hitch carrier so I could attach a bike rack.
The Pope
The Pope
NC
2019 Honda Passport and Pilot (properly equipped) have a 5000lbs. towing rating.
I hope that FoMoCo doesn't let Honda beat them in this category.......
Jomo
San Diego
Mazda
From the recent info on the Bronco Sport, it can be ordered with a class 2 towing hitch. 3500 lbs max.
The towing capacity for the Sport should be between 2000 and 3500 lbs, otherwise a class 2 hitch would not be necessary. Even at 2000 lbs, this is significantly better than the Honda CRV which is a competitor.
Both the Honda Passport and Pilot are considerably larger. The regular Bronco should compete with them, towingwise, not the Bronco Sport.
The Pope
The Pope
NC
Whether or not FoMoCo considers the Passport or Pilot a competitor or not to the Sport is their choice, but FoMoCo needs to realize that they are a factor in my (and several others) buying decisions as the Passport is the same size as my 2007 Mercury Mariner which I'd be replacing.
Also, not everyone wants a vehicle with a CVT.
The Pope
The Pope
NC
Well............. a measly 2000 Tow Rating...... smh........
2019 Honda Passport and Pilot (properly equipped) has a 5000lbs. towing rating.
Honda Beats Bronco Sport in Towing.......... WTF!!!!!!!
My current 13 year old vehicle has a better towing rating with 13 year old technology....... smh.....
AND .... AND FoMoCo has let it's DIRECT COMPETITION even beat it a this!!!!!! SMH!!!!!!
rms34208
Ford Escape 2013 SEL
If Ford would offer the 2.3 Ltd engine just like the Ranger towing could top 7000 lbs
Washburn
NC USA
2010 Ford Escape Limited AWD / 2005 BMW 330Ci ZHP / 2014 Mazda6 Touring
This.
I wonder what the chances are of the 2.3L becoming an option in 2022 or so....
nhmaina
New England
Honda Pilot 2011
I also, would like to see a higher tow capacity. 2000 lbs is just too low. If it can get closer to the Cherokee, say #3000, that would be great. Actually, I would settle for #2500 in the base or big ben models, every 500 lbs counts... I tow a utility trailer so it depends on what i am hauling, and I often don't know how much it weighs due to wet vs dry loam, how generous the loam guy is with his 1/2 yard of loam or 2 yards of bark mulch, etc.
General_Tso
Melbourne, FL
I just bought mine and wanted the hitch installed. The dealer said the parts are on back order with no ETA on delivery. I don’t want the UHaul under the bumper hitch look, so it’ll likely be a few months before the Ford part becomes available.
realworld51
Trailer + motorcycle = ~1700lbs so my OB will handle it, though not as easily as the 2.0L Escape...
Ford Bronco Sport Towing Capacity..... What's your Minimum.? 2000 LBS? 3000 LBS?  More? IMG_0999.JPG
