Towing Capacity..... What's your Minimum.? 2000 LBS? 3000 LBS? More?
The Pope
NC
1977 F250/2007 Mercury Mariner/2014 Infiniti Q60x/2011 Kawasaki C14
My 2007 Mercury Mariner is factory rated for a Max of 3501 LBS., so for me, that's my minimum for the Sport.
Just for a reference... the Honda Pilot & Passport AWD's are rated for 5000 LBS., so to be competitive with what I "think" will be a similar sized competitor, hopefully the Sport will have a similar rating.
FirstOnRaceDay
Devin
Toledo Ohio
2000 Mercury Grand Marquis, 2017 Honda Civic, 2019.5 Chevy Silverado
Jeep Cherokee is also 4500lbs with its towing package. So yes I think 5000lbs SHOULD be the ball park for the towing package. I’ll be OK with 4000 but I think ford needs to be very aggressive in its towing abilities
however the C2 platform cousin Escape only has a max of 3500 as does the Edge.
Explorer has 5600 but that’s with its 400lbft motor.
Motorpsychology
Chris
Prescott, Wisconsin
'18 Ford Escape, '09 Mercury Mariner, '17 Suzuki V-Strom 650, '80 Kawasaki KZ750 (Bought new)
Apples to apples, would be the Honda CR-V: 1500lbs, I think the CVT trans is probably the limiting factor. 5 X 8 single axle trailer for towing an ADV & dual sport bikes- 1800lb towing is fine fo me.
FirstOnRaceDay
Devin
Toledo Ohio
Most of the smaller SUVs have CVT or just a really weak <2.0L motor.
but yes most only have 1500-2000lb of towing. But some like the Cherokee pushes 4000lb I think ford definitely needs to fit in there some where over 3000 under 4500
Motorpsychology
Chris
Prescott, Wisconsin
I would guess the Sport, being derived from the C2 Escape platform, will have a slightly less than 3500 lb towing, slightly more GCWR, owing (hopefully) to heavier "built very rugged" vehicle components.
Bertman
Bert
Denver
2012 VW Jetta Sportwagon TDI, 1972 VW Super Beetle, Suzuki Burgman
I don’t plan to tow anything, but I would like a factory installed 2” rear hitch carrier so I could attach a bike rack.
The Pope
The Pope
NC
  • Thread starter
  • Thread Starter
  • #7
2019 Honda Passport and Pilot (properly equipped) have a 5000lbs. towing rating.
I hope that FoMoCo doesn't let Honda beat them in this category.......
Jomo
San Diego
2014 Mazda 3
From the recent info on the Bronco Sport, it can be ordered with a class 2 towing hitch. 3500 lbs max.
The towing capacity for the Sport should be between 2000 and 3500 lbs, otherwise a class 2 hitch would not be necessary. Even at 2000 lbs, this is significantly better than the Honda CRV which is a competitor.
Both the Honda Passport and Pilot are considerably larger. The regular Bronco should compete with them, towingwise, not the Bronco Sport.
The Pope
The Pope
NC
  • Thread starter
  • Thread Starter
  • #9
Whether or not FoMoCo considers the Passport or Pilot a competitor or not to the Sport is their choice, but FoMoCo needs to realize that they are a factor in my (and several others) buying decisions as the Passport is the same size as my 2007 Mercury Mariner which I'd be replacing.
Also, not everyone wants a vehicle with a CVT.
