Higher ramps?
Mrmike
Syracuse, New York 13219
I've been a mechanic all my life and have always done the oil changes on all my cars. Now that I'm 80 years old, and have a bigger tummy, I'm having problems. I have a really nice set of Rhino ramps that I use. The problem is they only lift the wheels 7" off the ground. It's getting harder to get under my OBX to change the oil and filter. Does anyone know of manufactured or homemade ramps that would give me some higher ground clearance?
Davexxxx
MO
2024 Bronco Sport, 2023 F150 Powerboost 501A
A neighbor built some really nice ramps out of 2x10 scraps he had from a large deck project.
They were heavy to move around but about 1' tall and I wouldn't have been worried about being on them,
max the dog
warren
maine
L8000, Excursion, F350, escape, BL, Hummer
If you have the room get a single post lift. Works slick.
Bill G
San Gabriel Valley, CA
Also might check out the folding ramps advertised at Harbor Freight and others. I’ve seen both pneumatic and electric advertised, and have seen one in use. Folds down flat and could be left under parked car.
IF I were planning to spend a lot of time under my BS I would check closer into them.
Mrmike
Mrmike
Mrmike
Mrmike
Thanks for that video. Very eye opening. These ramps cost more than the ones shown and may be heavier material. I'm going to buy these ramps anyway. They will work great to get my snow thrower, garden tractor, and even my pressure washer up in the air where they will be easier to work on. At 80 years old it's harder to get down to ground level these days.
Area 51
Slate, WV
2023 Bronco Sport Badlands-Area 51; 2012 F-150 and now 2025 Badlands
wireman
Murrieta
sajohnson
Sherman
MIDDLETOWN, MD
Hi Mike,
I hear ya about getting down on the ground -- not to mention back up.
I checked out the Amazon link. I've never seen ramps like that -- interesting design.
I noticed that they only have 4 ratings which is not enough to be very helpful.
Also, in the video Eric linked to some very similar ramps are shown tipping forward at about 12 seconds in:
The review of those ramps starts here:
Clearance to vehicle and ramp sliding are potential issues. We use thin rubber mats to prevent our RV ramps from sliding.
You might consider Major's suggestion -- "floor jack / jack stands." Here's a related thread:
https://www.broncosportforum.com/forum/threads/recommended-jack-stand-placement.7064/
Kent linked to this video about these ingenious jack stands that solve the problem of the jack and stands needing to be located at the same point. They're pricey, and not absolutely necessary, but a slick solution:
All of our previous vehicles have had a centrally located place to jack the front end up which makes life easier (jack it up once, place jack stands) but I'm not aware of a central jacking point on the BS.
Mrmike
Mrmike
Hi Mike,
Sajohnson
Thanks for your response. Those jack stands are pretty cool but don't raise the car high enough for my purposes. The ramps I'm buying are not the ones in the video. The ones I am buying are made in America not China. I think that speaks for itself. Also, as I said, they will be great for cleaning and sharpening the blades on my John Deere Garden tractor. Changing the oil on my tractor, snow thrower, and pressure washer. If only I could balance my Kymco scooter on them for an oil change they would be perfect.
sajohnson
Sherman
MIDDLETOWN, MD
Sajohnson
Sounds good! I didn't realize they are made in America -- that's great, and hard to find.
It's not that *everything* made in China is garbage, but much of it is. The inverse is true with products made in the USA -- most are good, but of course there is some junk.
<Later> I just checked the Amazon link (above) and it appears they are made in China:
Ford Bronco Sport Higher ramps? 1738099975689-47
Of course, as I said, that does not necessarily mean they are poor quality. I like like the basic design. Even though I have a 2-post lift in my garage, I'd like to have something like those ramps -- but I would want to see more than 4 reviews before buying, unless they were made by an established company with a good reputation.
One thought, regardless of where they are made, is that manual bottle jacks can be tedious. Pneumatic ones are much easier to use (but more $ of course). For occasional use manual jacks are OK.
At about -23 seconds in the short video on the Amazon page, a vehicle is shown rolling onto the platform, which tips forward significantly. That's to be expected since the only support is the jack in the center, but it doesn't look good.
They may be fine. I tend to be pretty critical.
On the jack stands, while I think ramps would work better for the uses you mentioned, the stands shown in the video above do have a max height of over 16", and of course the front end would be even higher. Here's an illustration with dimensions:
https://www.etamfg.com/shop.html?store-page=Rennstand-Each-1-Piece-p252276669
ATLAS BLUE BADLANDS
PNW
2024 BADLANDS
