How is this been going for you?It’s the internet! We don’t need to provide sources for claims we make! Heck! Look what we tow with ours!
Funny,
Depending on which trim Escape you traded, the tow rating can be quite different. For example, my Badlands is rated at the max tow capacity for the Bronco Sport line (2200 lbs) and the wife's 2020 Escape Titanium is rated at the max tow capacity for the Escape line (3500 lbs).I traded the Escape in for the Bronco Sport because I like the BS better, but it is almost the same vehicle.
I think it was a 1.5 liter Ecoboost 3 cylinder. But I was only towing 2000 lbs. It is just, some people don't think you should tow anything because it is not body on frame, it has a small engine and the vehicle is not a bigger F150. But if you know what you are doing you can tow safely, even if you are towing with a motorcycle (and they do).Depending on which trim Escape you traded, the tow rating can be quite different. For example, my Badlands is rated at the max tow capacity for the Bronco Sport line (2200 lbs) and the wife's 2020 Escape Titanium is rated at the max tow capacity for the Escape line (3500 lbs).
You should be fine with 2000 lbs, assuming your Bronco Sport has the towing package.I think it was a 1.5 liter Ecoboost 3 cylinder. But I was only towing 2000 lbs. It is just, some people don't think you should tow anything because it is not body on frame, it has a small engine and the vehicle is not a bigger F150. But if you know what you are doing you can tow safely, even if you are towing with a motorcycle (and they do).
Plus I only go up to 40 miles from me and there are no highways around here (just 2 lane roads).
