- First Name
- Mark
- Joined
- Oct 30, 2021
- Threads
- 119
- Messages
- 6,732
- Reaction score
- 13,140
- Location
- St. Jacob, IL
- Vehicle(s)
- 2021 Badlands | 2020 Escape
Ok, here's the scoop:I'm going to test this today; I don't think you can manually set the transmission to 1st unless you are using an off-road G.O.A.T. mode. Stand by...
- With the G.O.A.T. mode set to NORMAL and the transmission set to manual, you CAN select 1st gear.
- As long as you are accelerating and/or holding your speed the transmission will allow you to take the engine to redline in 1st.
- If you accelerate in 1st gear up to approximately 10 mph and take your foot off the pedal, the transmission will stay in 1st and you will get some engine braking. You won't get it immediately; the computer seems to hold whatever RPM you were at briefly, then SLOWLY closes the throttle.
- If you accelerate above 15 mph and take your foot off the pedal the transmission will immediately upshift to 3rd. You can manually downshift to 2nd at that speed, but you cannot manually downshift to 1st until 5 mph or less.
The bottom line is engine braking is limited. If you live somewhere that has a lot of long downhill grades expect to replace your brakes more often.
