Centering digital speedometer
Tamihart
2024 bronco sport
I have a 2024 Outerbanks and have tried everything and can’t get the digital speedometer centered on the screen behind the steering wheel. I’ve tried the suggestions of taking lane keeping off and using the calm screen but it is still located in the bottom right of the screen. I’ve also checked the owners manual and there are no instructions. I’m thinking maybe this isn’t even an option for the 2024s. Can anyone help? Thanks!
Ford Bronco Sport Centering digital speedometer IMG_2278
Deleted member 6350
Did you happen to check the button on the very end of your blinker lever ???
Tamihart
Tamihart
2024 bronco sport
Yes. This is how I turned off the lane keeping. The digital speedometer still stays to the right after I turned it off.
That's the lane centering display. Lane centering (different feature from lane keeping) is part of the CoPilot 360+ package, and it usually isn't visible until you turn on cruise control. Try turning cruise control on and off and see what happens.
Deleted member 6350
[/QUOTE
O.K. what about the button on the left of the steering wheel ???
Tamihart
Tamihart
2024 bronco sport
I don’t think that moves from that spot. Is there a reason you think it should?
There is a thread on this forum from April 10, 2024 with pictures showing the speedometer in the middle.
I don't have lane centering on my car, only lane keeping. The button on the end of your turn signal turns lane keeping on and off. If I turn off lane keeping on my car the digital speed indication enlarges and moves to the center of the display.
TNFurb
Nashville
Do you drive an Outerbanks? I need to check mine but I don’t think I’ve ever seen the Speedo move to the center of my display either.
If that is true for Outerbanks it makes my annotated pic incorrect
Ford Bronco Sport Centering digital speedometer IMG_6478
Grantorino
Donna
I found when I accidently hit the button at the end of the turn signal lever that it moves the odometer number. It took me awhile to figure out I had hit the button and switched the lane assist off. (You can switch the lane alert setting both on the info screen and the button on the turn signal lever.)
bstn rnr
JP
Tennessee
Also, in settings, if you have collision warning with a visual turned on, it will display that lane and you can't get the speed back to center. If you see a pic of a bronco in that spot when you're close to another vehicle, that's probably the issue.
TNFurb
Nashville
You have to turn the distance setting off in the settings menu on the infotainment screen. Then the Speedo moves to the center. Pics attached.
Ford Bronco Sport Centering digital speedometer IMG_0534
Ford Bronco Sport Centering digital speedometer IMG_0535
Sojourner
Maryland
With all the "you gotta check here. And here. And here" I can't help but remember the "how do I get that darn VCR to record my favorite show each week" uber-discussion!
Not criticizing, just commenting on how crazy operating a car these days is with all these features. TBH, one of the reasons I joined this forum: it can be daunting.
Cheers!
