Deleted member 6599
You are correct, the grills are part of the center dash. There must be a clip or retainer that goes under the A pillars. I can see pop clips along the center section by the defrost vents. So it's possible that if you pop the clips in the center, it may just pull out from under the A pillar, but I have not disassembled this myself.
I was going to remove mine and replace my factory tweeters when I replaced my speakers, but I decided to leave them be for now since I was very happy with the speakers I chose.
There is a bolt under the A pillar that is holding the grill to grill dash section down. To remove pillar, grab top of it with your hand and pull outwards then lift up.
Deleted member 6599
Finally installed my amps, LOC and crossovers. I’m not a professional, so it’s not the prettiest. I put the crossovers and bass knob in the glovebox and mounted everything else on the rear seat. Took me two long days.
Ford Bronco Sport Installing aftermarket speakers and sub in Bronco Sport! 78D2A45A-7D6F-4820-BC4D-3FC8CCDA214D
Ford Bronco Sport Installing aftermarket speakers and sub in Bronco Sport! BD4F5ADE-26B5-4CCD-A707-EBB9279F6A2C
Ford Bronco Sport Installing aftermarket speakers and sub in Bronco Sport! 0CBC1D5D-6044-46C5-AAD3-BC3A1F571C15
M3H7363
2023 Maverick hybrid XLT
I guess there's no flipping the back seats down and hauling a big item in the back.
Deleted member 6599
I can still put the seat down. I can just toss a blanket or something over the amps. I have the full size spare so didn’t have room around the tire.
Ford Bronco Sport Installing aftermarket speakers and sub in Bronco Sport! DD964819-D94B-4DBD-A603-A12459261927
2XIPA
PNW
Accord, Civic, and a Subaru
New member resurrecting on an older thread. Anyone replace the B&O subwoofer speaker? I know it's a 6X9 but nothing else about its size. TIA
ChefDank
Nick
New York
When you first tried the Rockville rockghost in the spare why didn't you like it?
Also was there any space between the sub and the cover in the back?
I'm thinking about the JBL basspro hub but it's 2 inches higher than the rockville.
2XIPA
PNW
I also considered installing a spare tire sub when my BS BL arrives. It was the OP's comments in thread #13 that eliminated that option for me. - The Rockville 8 inch sub in the spare tire area was more fault to the sub itself. It was barley noticeable.
I'll be looking for a solution in the right rear cargo area under the panel where the B&O sub sits. I'm thinking a sub being buried under a heavy rubber cargo mat would loose quite a bit of definition and volume compared to under the panel.
I'm also considering a Dayton Audio DSP-LF Low Frequency DSP Controller to get rid of any bass bumps and any equalization related to the B&O sub.
By way of background, I've heard the B&O system and to my ears it's as bad as described by other BS BL owners.
UncleRenty
Ian
Orlando, FL
2022 BS Badlands, 2021 Tesla MYLR
Another thread of someone doing the same as everyone else, with pics.
I used the Metra 82-FD1 (amazon: B09NB32MV6) speaker kit. I had to use my dremel to cut off the tabs in the middle, then I cut the cable adapter a slot in the side of the standoff. After that I superglued it into place.
Ford Bronco Sport Installing aftermarket speakers and sub in Bronco Sport! 1666381432399
After that, I added the speaker mounting foam (amazon: B00WW6MZLM) to the front of the riser. If you have enough you can do the back of the riser as well where it mounts to the interior door panel.
Ford Bronco Sport Installing aftermarket speakers and sub in Bronco Sport! 1666381731149
The speakers I got are Pioneer TS-D65F D (2 sets, amazon: B0777SKV7D). As with most speakers you can change the angle of the tweeter:
Ford Bronco Sport Installing aftermarket speakers and sub in Bronco Sport! 1666381958982
The screws shipping with the speakers are too small for the screw holes so I recommend just drilling a small hole in the side of the riser and using the screws that ship with the speakers:
Ford Bronco Sport Installing aftermarket speakers and sub in Bronco Sport! 1666382064591
This is the finished speaker:
Ford Bronco Sport Installing aftermarket speakers and sub in Bronco Sport! 1666382095939
I added the open-cell memory foam (1/2"x1/2" - amazon: B07W5GGVFT) which seals against the door panel:
Ford Bronco Sport Installing aftermarket speakers and sub in Bronco Sport! 1666382206228
Installing was easy:
This is the first secret screw:
Ford Bronco Sport Installing aftermarket speakers and sub in Bronco Sport! 1666382395727
This is the second:
Ford Bronco Sport Installing aftermarket speakers and sub in Bronco Sport! 1666382478072
Insert a spudger under the panel with the window controls and lift straight up to get access to the 10mm bolts.
The screws under the reflector are the same as the two screws under the door.
Here is the inside of the door. You can see how I angled the tweeter upward:
Ford Bronco Sport Installing aftermarket speakers and sub in Bronco Sport! 1666382658724
Finally, here are some pics comparing the speakers. This is the new speaker versus the B&O front speakers:
Ford Bronco Sport Installing aftermarket speakers and sub in Bronco Sport! 1666382841608
This is the rear B&O speaker:
Ford Bronco Sport Installing aftermarket speakers and sub in Bronco Sport! 1666382848328
These hit hard. I ordered a JBL BassPro powered sub for the spare tire sub, but I am thinking of not using it. I may end up looking for a 6x9 sub instead and replacing the existing speaker mount for it.
T_Stiffler
Tj
Pittsburgh
2021 bronco sport
So in case your wondering we just upgraded all speakers to the following. Using only the factory radio.
Alpine R-Series 6.5" 100 Watts RMS at 4 Ohms 2-Way Coaxial Speakers with H.A.M.R. - Pair (RS652)
Changing to a coax speaker meant I got to also keep and use the factory tweeters in the upper dash.
The sub of choice for me was Rockford Fosgate Punch P300-10 which was absolutely awesome.
SICK set up dude!!! I'm in process of doing mine now, currently having a head unit issue not giving proper connection to my driver side speaker, or my driver side dash tweeter. Just curious if you replaced tweeters? And always curious if you used the "Plug-n-play" cord to power your amp? Dealership is giving me a run around because the factory left door speaker went out & I replaced them still having same issue so obviously its a connection issue somehwere with my head unit no giving proper signal to my tweeter & door speaker, theres only one connection to the door speaker that could be the issue & its not that seeing as I've replaced them twice & tested the current speaker. Thanks a lot!
Grey Ghost
Clem
Jamestown Tennessee
bronco
I’m absolutely interested in replacing the speakers in my OB w/o the OB package. Quick questions:
1 - do you have to remove the whole door panel, or can you just pop off the speaker grill? Did the panels easily pop off, or was there a struggle? When you popped the panels back on, were they tight?
2 - what color speaker wire was used to tap into the sub? And did you tap into the front or back speakers?
Door panels are easy to take off and put back on. I did remove clip for window switches and power mirror connections .... very easy kind of amazed me
SnoopyBroncoSport
Markham, ON, Canada
2023 Ford Bronco Sport Badlands AKA: DONK
I have the b&o system in my BL and I’m not impressed. I’m planning on changing the front and rear speakers and maybe the sub. My question is: has anyone changed the b&o speaker in the dash? I would think it would need replacing as well but no one has mentioned it yet. Thanks!
WildFord
Los Angeles
'22 BS BL
my question as well, I just saw another thread on tweeter connector...but not sure those came out of the dash or door. I had trouble removing the factory tweeter from the door as well. for the dash ones, it seems like it needs to remove allot of panels to get to . I have not come across specific dash tweeter replacement. or I just missed it....
These B&O in the BS are from bottom of the B&O part list. Just today I truly realized how much bass I was missing when I, just so happened, listened to some songs off my phone in my other car, also with B&O, and then within a short period got into the BS and kept playing the same song.
wow.....what a difference!! sound quality in general. sure the other car is more expensive, but the "sub" we have back in the trunk is not exactly doing much good. After I replaced the speakers in the door with Powerbass speakers soon after I got the car, I thought the sound was acceptable. and that is about right.
tho I'm not sure I would sacrifice already limited trunk space for a big box sub woofer
gatornek
Miami
That might have been my thread. I'm in the midst of replacing my tweeters. But I don't have the BO. So its only the corner tweeters for me. I think you have a center speaker on the dash too.
Removing the panel is not a big deal. What you need is plastic trim tool. Then all you gotta do is carefully removing the A pillars by pulling out then up. Remove a few bolts. Then simply pry the top panel off with your tool. Again, slow and careful is the name of the game. You want to find one connector, pop it, and then slide to the one right next to it.
WildFord
Los Angeles
'22 BS BL
thanks!
I think I didn’t want to mess with the A pillar piece last time.
I may have seen a video since on removing that. I will have to look for it again.
gatornek
Miami
thanks!
The automatic reaction when you pull on something and hear 'popping' is to stop and panic because you think you broke something and won't get it right again.
That's not the case at all. The A-pilars are actually easier than the top dash. Pop it OUT. Pull it UP. Don't worry about the rubber bungee. It doesn't activate the airbag if you pull too hard. Its simply there to keep the a pillar from flying too far if the airbag deploys.
