Deleted member 6599
There is a bolt under the A pillar that is holding the grill to grill dash section down. To remove pillar, grab top of it with your hand and pull outwards then lift up.You are correct, the grills are part of the center dash. There must be a clip or retainer that goes under the A pillars. I can see pop clips along the center section by the defrost vents. So it's possible that if you pop the clips in the center, it may just pull out from under the A pillar, but I have not disassembled this myself.
I was going to remove mine and replace my factory tweeters when I replaced my speakers, but I decided to leave them be for now since I was very happy with the speakers I chose.
