Where should I hook a tow strap?
Maxwellian
Maxwell
Los Angeles
‘21 Bronco Sport
I do not believe the bracketry depicted in this installation document will support recovery/towing operations. The photo at this link shows how the factory tow hooks on the Badlands attach to the unibody. Note the reinforcement brackets and how they are welded to the unibody. If your bull bar doesn't include this level of structural attachment to the vehicle's unibody then I would not use it for recovery/towing ops.
Yeah, all the nudge bars just use the bolt locations that stabilize the tow hooks from turning. Besides being at least 4x as strong as any one of those bolts, the tow hook is attached deeper in the frame in a presumably stronger location. The eight bolts would probably be strong enough, but unlikely to be equalized, and attached to frame parts of dubious strength.
compass crusher
Nathan
linktr.ee
What's the difference from being towed in the rear from your tow hook attached to the hitch (that isn't welded) and the bull bar on the front?
Ford offers a tow hook that screws into a fitting on the rear bumper for recovery/towing operations. The bumper attachment to the unibody is designed for this purpose. If you get the factory tow option the receiver mount replaces the tow hook.
If you get a minute, crawl under your car and look how the bumper is attached to the unibody. I assure you it's far more sturdy than the brackets used on the aftermarket bull bars I've seen.
compass crusher
Nathan
linktr.ee
Liked "The bumper attachment to the unibody is designed for this purpose. If you get the factory tow option the receiver mount replaces the tow hook."
Great explanation ?. Thank you Mark.
Next time I'm up Black Bear Pass and I'm in need of recovery, I'll be sure to contact my local dealer to help ??.
Next time I'm up Black Bear Pass and in need of recovery, I'll be prepared, and not worry about a tow bar, because I'd already have it, along with a partner rider, or a winch. :like:
Maxwellian
Maxwell
Los Angeles
‘21 Bronco Sport
The tow hitch is pulling on much larger bolts in shear, well equalized, bolted to a place on the frame meant to take towing loads. The bull bar is levering on much smaller bolts, in tension/bending on frame parts of unknown strength. Not an engineer, but have some idea of the forces and structures needed. I think you’d stand a good chance of ripping the bull bar and the pieces of the frame it bolts to off in a recovery.
Maxwellian
Maxwell
Los Angeles
‘21 Bronco Sport
I can assure you two of those little tabs have a minimum breaking strength far lower than your tow rope or winch line. These are the main connection point for the nudge bars I’ve seen, with one more small bolt below.
Ford Bronco Sport Where should I hook a tow strap? IMG_0067
