Biggest size tires for Bronco Badlands without doing a lift?
fsjdw2
Jerrod
Maine
As mentioned in about 10 threads before this… Height is not the problem, width is. When you turn your tire will rub on pinch welds if you go bigger than 245-70r17. I’ve got 235-65r17’s
Colonel Angus
Dean
New York
Mrmike
Syracuse, New York 13219
What about the OBX? What's the biggest 18" tire you can run with stock suspension?
jkeaton
Greatest country on earth!
This one
And why does this necessarily reduce mileage?
It's a bigger tire, thus heavier. Adding weight reduces mileage. How much? Have not seen any data to support the hit, but I'm sure there has got to be some sort of mileage loss due to the increased weight. Also, maybe some performance loss, especially for the little engine that could (1.5L).
Horse n Buggy
Stoge
Florida, USA
In particular, 1lb of rotating weight roughly equal 8lbs of static weight with regards to your vehicles performance. So if your stock 225/65/17s on the Badlands weight say 29lbs, changing all four corners to 245/65/17 KO2s (34lbs) is an additional 20lbs of rotational mass, which has a similar effect of adding 160lbs of static weight. Any additional weight requires the engine to work harder to get it moving, making acceleration slower, and using more fuel to get up to speed, and increasing the amount of effort it takes to maintain speed.
Additionally, These example tires have 1” larger diameter, effectively lifting your car, increasing airflow under the vehicle, increasing it aerodynamic drag, and further decreasing fuel efficiency by again requiring the engine to do more work to accelerate and maintain speed.
But they look better and would preform better in off-roading conditions
