I just wanted to say…the 2.0T have a lot of documented issues and these are very common:It’s not really fear mon
They definitely fixed the coolant intrusion issues by redesigning the block and leaving the sidewalls thick while adding slimmer water jackets.
The main issues on the 1.5 3cyl are:
- Water pumps failing
- Lack of belt tensioner
- Pretty bad vibrations at low speeds
- Very bad vibrations at idle with the AC on
- Coolant Intrusion
- Cracked Exhaust Manifold
- Turbo/Boost Control Solenoid Failure
- Low-Pressure Fuel Pump Failure (LPFP)
- Carbon Build-up
the judge is still out for the new Dragon engines.
