A bit confused by this.
It appears that TSB (technical service bulletin) 22N18 is available on all 1.5L engines after the recall work involving the drain tube and PCM programming is complete. This provides for one-time replacement of high-pressure fuel injectors in the event an OEM injector cracks. I believe this is the genesis of the rumors we've been hearing from owners told that their fuel injectors are warranted for 150K. You can read more about it here:
https://www.tsbsearch.com/Ford/22S73
BroncMan
Sioux Lookout, Ontario
kr-photography.ca
I also got the letter.
- I did not notice any symptoms as described / smell, etc.
- I contacted the dealer and they ordered the part anyways and want / must? replace it anyways.
Is this normal? ... to avoid any legal problems / liability?
Thanks
So, only if the injectors crack...correct? If they are fine now, we don't have to take it in?
Yes, that's the way I read it:
When FSA 22S73 [this is the recall to install the fuel drain tube and PCM software] is completed and claimed, customer satisfaction program 22N18 (to be released in January 2023) will be automatically activated on the VIN, which will provide a one-time repair to replace the high-pressure fuel injectors in the event of a cracked high-pressure injector...
Well good. I could wait for 60 to 70K miles or more, then ask for them to be replaced under this customer satisfaction program. I could make one crack...
