Jmuns
2022 Bronco Sport BL
Cool! Where did you find that paint at?
I saw it posted in a Bronco Sport group on Facebook. I ordered from Amazon but I just saw it in an art store in Houston also. So you can check local art stores as well.
Montana Cans GOLD Spray Paint, 400ml, Golden Yellow, Orange, MXG-G1240 https://a.co/d/2mXLqkS
CrazyKZ
Ken
Allen, TX
Yea I love it. Looks better than the red for sure.
Really? I’m actually still leaning toward red! I have amber fogs and I think the yellow-orange color would conflict. Which red had you tried?
Jmuns
Just a standard red Plasti Dip. I liked it, but I like them better orange. Maybe if I had used a really bright red I would have liked them more. I used the red Plasti Dip so I could easily remove it if I didn’t like it.
CrazyKZ
Ken
Allen, TX
Should I plastidip spray or paint spray? Will acrylic lacquer paint stay on?
Jmuns
How easy do you want to remove it if you change your mind? If you’re unsure at all I would go the plasti dip route at least first. Drive around for a couple weeks and see how you feel about the color. If you like it you can always spray paint it later to any color you want.
Any paint will adhere to the hooks. I just used some scotch brite pads on them, cleaned with alcohol, then painted them.
davidb1841
Bruce
NC
Went thru the carwash with my Bronco Script Fender Emblems and the CHinese MQM 3m knock off tape.
....And they are still on the Bronco.....(Miracle of Miracles)
Ford Bronco Sport What did you do TO your Bronco Sport today? 0323232016 (1)
davidg4781
Yesterday...
I finally had a day off after purchasing my BS. I was able to check my oil and take the extra few pounds of air the dealer put it. I checked the oil once when I got home that night but just wanted to make sure.
Today I got to drive it in the rain. Wipers worked great! I put my air compressor in the back but there wasn't a good place for it to fit securely. Maybe if I take it out of its bag. I might have a tote in the garage I can throw stuff in. It'll have to wait until I'm off on Sunday or week after next.
Kraken23
Allen
St. Louis, Missouri
2022 BS BL
Installed some grill aka Raptor lights today. One of them is slightly crooked but it still looks good.
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_0737
JohnSilver
Knoxville
Haha that's awesome I just came to post mine ! Btw what did you run to? I tapped several fuses until I found one that wasn't hott. I think it was 17 (unused) only run when engine is on, other light fuses were all hott and the lights wouldn't shut off when the vehicle was off. I may try some others because my only grip is they don't light up when locking or unlocking.
Ford Bronco Sport What did you do TO your Bronco Sport today? PXL_20230410_005151408.PORTRAIT.ORIGINAL
Look sick at night
Ford Bronco Sport What did you do TO your Bronco Sport today? PXL_20230410_005607850.MP
Kraken23
Allen
St. Louis, Missouri
2022 BS BL
Look sick at night
I had installed the Tectico dual color side marker lights last year so I used the same connection that I used for the “white” lights on them. Basically they are only on when the headlights are on. I thought about running them all the time but decided I only wanted them on when the headlights were on.
JohnSilver
Knoxville
Was it a fuse or did you splice em in with the other wires?
Edit nvm I see what you are saying. Those side marker lights are my next purchase.
Kraken23
Allen
St. Louis, Missouri
2022 BS BL
Installed a set of the Ford roof racks to my Outer Banks BS.
Fender flare Friday! Some have had problems with these not staying on. I installed these myself, and I can tell you that you have to use considerable force to push the flares in far enough to get the installation clips to engage in the slots in the fender flares. If you had these installed on your car you might check to see if the clips are properly seated in the slots.
Ford Bronco Sport What did you do TO your Bronco Sport today? 20230410_090851
Ford Bronco Sport What did you do TO your Bronco Sport today? 20230410_090826
