Jmuns
2022 Bronco Sport BL
Thank you, and thanks for the tip. I did the rear tailgate emblems awhile back. Super easy, flat surface.
So many coats with the tow hooks, though.
Yea when I originally plasti dipped mine red it took soooo many coats to get the whole hook and have it even. If you’re not careful removing the plastic you’re using to protect everything and it runs against the hook you’ll end up imprinting or smearing the plasti dip. I did it the first time because I touched it and it was dry, but still very soft underneath and I didn’t realize it at the time. If you have to take the plastic off around the hook use a razor blade to cut the plastic from the top and bottom (or sides) so you can remove it gently without it touching the hook at all.
Scott_Anderson_
Scott
Arkansas
2021 Badlands Cactus Gray
I didn’t even think about that in terms of the bag smearing. I may try to cut the bag out with a razor per your suggestion. What I’m more concerned or curious about is how long to wait before applying the glossifier. I’ve never used it before.
Jmuns
I didn’t use one, but as long as it’s not tacky when you touch it you should be fine. If you have the time to wait, and don’t need to drive, then waiting longer would be best I’d assume.
Winds of Change
Chicagoland
Had a great day at the Badlands with Tigger (Rick)
Mark S. You should have been there. So what did I do to my Bronco today? I let him run wild!
Ford Bronco Sport What did you do TO your Bronco Sport today? 20230326_120338
Ford Bronco Sport What did you do TO your Bronco Sport today? 20230326_125328
Ford Bronco Sport What did you do TO your Bronco Sport today? 20230326_125537
Ford Bronco Sport What did you do TO your Bronco Sport today? 20230326_104351
Well played boys!
Changed my tow hooks from red to orange. This spray paint was posted in a Facebook group. It closely matches the Badlands badge. It’s pretty indistinguishable and looks great.
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_0496
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_1061
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_1062
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_1063
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_1064
You garage floor is oddly familiar:
Ford Bronco Sport What did you do TO your Bronco Sport today? 1679888405237
Scott_Anderson_
Scott
Arkansas
How’d it turn out?
From what I can tell, quite good. I let it dry overnight. But it was sort of a mad dash to clean it up and get out of this house this morning. I will post some photos later this afternoon.
leftbehindmtb
Stuart
Covina, CA
Put the rear number protector on that I used points for. Finally going to put the HRG lift kit on this weekend. It’s been sitting in my garage for months.
DirtyLuke
Luke
Denver
21' BS BL, 18' Forester
Installed a GMRS radio and cleaned up some old wiring while I was at it this weekend. The radio is powered by my Auxbeam 8-gang relay board. The 3-way switch in the glove box switches the Auxbeam panel from an aux power fuse to a constant on fuse, in case I want to run the radio or lights while the car is off. This thread from a ways back helped a lot.
Ford Bronco Sport What did you do TO your Bronco Sport today? PXL_20230325_193721947
Ford Bronco Sport What did you do TO your Bronco Sport today? PXL_20230326_213656985
Ford Bronco Sport What did you do TO your Bronco Sport today? PXL_20230326_180418194
Ford Bronco Sport What did you do TO your Bronco Sport today? PXL_20230326_180406493
Ford Bronco Sport What did you do TO your Bronco Sport today? PXL_20230326_180428676
Ford Bronco Sport What did you do TO your Bronco Sport today? PXL_20230326_213821361
Ford Bronco Sport What did you do TO your Bronco Sport today? PXL_20230326_213807875 (1)
Ford Bronco Sport What did you do TO your Bronco Sport today? PXL_20230326_214130149
Ford Bronco Sport What did you do TO your Bronco Sport today? PXL_20230326_213733276
Mrmike
Syracuse, New York 13219
I like it! Looks great.
Looking at that picture with your glove compartment taken out. I want to access the ambient lighting wires in that footwell. I'm going to splice wires in them to hook up lit cup holders. Looks like I may be able to get to them with the glove box removed.
BillC
Halifax, Nova Scotia
2023 Bronco Sport Outer Banks
Installed door sill plates, as the sills were getting scuffed. Straightforward application, and warranted by Ford to the end of our 6yr/120,000KM PremiumCare contract.
Ford Bronco Sport What did you do TO your Bronco Sport today? 20230328_110317
