Changed my tow hooks from red to orange. This spray paint was posted in a Facebook group. It closely matches the Badlands badge. It’s pretty indistinguishable and looks great.
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_0496
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_1061
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_1062
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_1063
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_1064
davidb1841
Bruce
NC
JJ
Sierra Foothills, CA
2022 Ford F-250 Tremor, 2022 Bronco Sport
They look fantastic! ??
KingofMandalore
Dan
North Ridgeville, Ohio
Did a quick rust bust and spray paint on my skid plate when I changed the oil a few days ago, the little bit of Ohio salt out there was starting to rust it after our not so awful winter. Did 2 coats, will add more as needed... I might remove the insulation pad in the future as it seems to be a sponge on the one side that just draws water up the 6 panel retaining tabs and lets em soak and rust out the plate. If you're picky like I am, beware lol.
Ford Bronco Sport What did you do TO your Bronco Sport today? 20230322_173935
Scott_Anderson_
Scott
Arkansas
2021 Badlands Cactus Gray
Let it dry longer than you’d think or what it says on the bottle if you can. Looks good so far. Best thing about plasti dip is it comes off easy if you don’t like how it turns out.
Thank you, and thanks for the tip. I did the rear tailgate emblems awhile back. Super easy, flat surface.
So many coats with the tow hooks, though.
Yea when I originally plasti dipped mine red it took soooo many coats to get the whole hook and have it even. If you’re not careful removing the plastic you’re using to protect everything and it runs against the hook you’ll end up imprinting or smearing the plasti dip. I did it the first time because I touched it and it was dry, but still very soft underneath and I didn’t realize it at the time. If you have to take the plastic off around the hook use a razor blade to cut the plastic from the top and bottom (or sides) so you can remove it gently without it touching the hook at all.
Scott_Anderson_
Scott
Arkansas
I didn’t even think about that in terms of the bag smearing. I may try to cut the bag out with a razor per your suggestion. What I’m more concerned or curious about is how long to wait before applying the glossifier. I’ve never used it before.
I didn’t use one, but as long as it’s not tacky when you touch it you should be fine. If you have the time to wait, and don’t need to drive, then waiting longer would be best I’d assume.
Winds of Change
Chicagoland
2023 Bronco sport
Had a great day at the Badlands with Tigger (Rick)
Mark S. You should have been there. So what did I do to my Bronco today? I let him run wild!
Ford Bronco Sport What did you do TO your Bronco Sport today? 20230326_120338
Ford Bronco Sport What did you do TO your Bronco Sport today? 20230326_125328
Ford Bronco Sport What did you do TO your Bronco Sport today? 20230326_125537
Ford Bronco Sport What did you do TO your Bronco Sport today? 20230326_104351
Well played boys!
You garage floor is oddly familiar:
Ford Bronco Sport What did you do TO your Bronco Sport today? 1679888405237
