- First Name
- Eric
- Joined
- Mar 19, 2022
- Threads
- 10
- Messages
- 2,166
- Reaction score
- 3,149
- Location
- Belleville, IL
- Vehicle(s)
- '08 BMW R1200 GS Adv, '23 Norden Expedition
What you missed is that a turbo removes the variation in the intake that makes the K&N work. Essentially a turbo makes an engine work more like a vacuum cleaner and less like a piston pump. It’s not vibration of the engine itself, it’s about the variation of intake vacuum. There essentially isn’t any variation on a small timescale when you have a turbo.I just played that full video, and can’t connect the dots between your recommendation for using a paper filter versus the point this gentleman makes about K&N. His point is that there is nothing that performs like a K&N for both flow and filter. That if you want peak performance, K&N is the way to go, and he explains the science behind that position. He makes it very clear that the only test where the K&N does poorly is in a static environment, meaning, a test that mimics the absence of an engine. But put a K&N on an engine with actual vibration, and the K&N filter is the best on the market.
Luckily I’ll only use mine with an engine.![]()
