GoHack
Gordon
Palmdale, CA
If you have a heavy foot, you'll notice the random hesitation from a stop. Especially after getting off the highway I notice. You hit the gas and it takes a second for it to respond. Every Ford I've ever driven does this including all 3 of my Dad's previous F150s. What this does is get rid of that hesitation so everytime you git the gas it feels the same and responds instantly. This makes the gas pedal jumpy at first until you get used to it.
Like I said some people who read this will know what I'm talking about and this is for them. I haven't seen anyone talk about it hear so I wanted to share that it's 100% worth it if you've been on the fence!
Okay, you have covered what this does for throttle response. Can you compare what the Pedal Commander does to what Sport mode does? If not, that is fine. Everything you have described so far sounds very similar to what Sport mode does.
I'm sure that being able to program in some setting that is softer than Sport but more responsive than the default setting could be a good option for some (me included). To me, the Sport mode is just too jumpy and could use some smoothing out.
delm
Atlanta
My first - and likely only - engine performance modification.
Love it. Love how well the engine "breathes" now. Clearly opens up the intake. I'd put one of these on a V12 that I used to own, and it was unreal. The "swooooosh!" of the intake was so cool, and the performance improvement was amazing. On this 2.0L, it's not all that, at all. You can hear the intake, but it's not loud. But it does deliver a handful of additional horsepower, which I was after, because of the bigger tires I've got on it. The additional ponies more than compensate for the added weight, and this thing runs!
Ford Bronco Sport What did you do TO your Bronco Sport today? thumbnail_AB62BE35-6E90-47E5-9528-8A8B2FBDAF9F
Ford Bronco Sport What did you do TO your Bronco Sport today? thumbnail_53683431-8020-4D78-82A6-E985182A6683
CrazyKZ
Ken
Allen, TX
I'm glad to hear someone putting a CAI on the Bronco Sport. I have put them on most all of my previous cars and loved it.
Just want to share the video that really convinced me that K&N (or any oiled) filters are not what I want to use on my turbo vehicle.
That being said, the actual intake piping is a good thing, from a restriction standpoint. Replacing that filter with a more robust paper filter would be my recommendation.
Take it or leave it!
delm
Atlanta
I just played that full video, and can’t connect the dots between your recommendation for using a paper filter versus the point this gentleman makes about K&N. His point is that there is nothing that performs like a K&N for both flow and filter. That if you want peak performance, K&N is the way to go, and he explains the science behind that position. He makes it very clear that the only test where the K&N does poorly is in a static environment, meaning, a test that mimics the absence of an engine. But put a K&N on an engine with actual vibration, and the K&N filter is the best on the market.
Luckily I’ll only use mine with an engine. :)
What you missed is that a turbo removes the variation in the intake that makes the K&N work. Essentially a turbo makes an engine work more like a vacuum cleaner and less like a piston pump. It’s not vibration of the engine itself, it’s about the variation of intake vacuum. There essentially isn’t any variation on a small timescale when you have a turbo.
Elegance
Kris
I know functionally it does nothing, but I bought this locking cover for the hitch.
Ford Bronco Sport What did you do TO your Bronco Sport today? 20230227_165504
delm
Atlanta
Maybe you’re thinking about a different video? That point is never made in this video. This video makes a compelling argument for why K&N is by far the best filter you can buy. And the very last words on this video are if you’re in any kind of doubt as to what filter to buy just do yourself a favor buy K&N.
as to your point that a turbo synchronizes, essentially with the vibration of an engine so to do away with any meaningful vibration the filter may utilize I have to respectfully disagree. Perhaps, in certain conditions that might be the case. But in real life, the filter end of my air in take system is pretty far away from the turbo unit and I have no doubt there is substantial vibration for K&N to do what it does.
CallMeBill
2022 Carbonized Grey Badlands
Even in Sport mode. If you put your foot all the way down there's a hesitation sometimes. This gets rid of that. I think it's a driving style thing.
But when i watched the video on Youtube from Pandaworks even they state that there is still some hesitation from transmission having to catch up. So do you find that true as well?
He does not address specifically in the video the turbo issue. What he does is discuss how the fibers of the filter move on an engine and how they don’t move when hooked to a vacuum. Again, it’s not physical vibrations that make it work but pulses in the intake pressure. A turbo is essentially the same as a vacuum.
I know that you are unmoved by all of this but maybe others will think twice.
Again, take it or leave it.
seoden88
Scott
Louisville, KY
'22 Bronco Sport Badlands
I don't think you would like this if you don't know what I'm talking about. This stops the unpredictable hesitation in the pedal. Especially if you have a heavy foot. Plus unlimited custimization of the throttle responce.
all it does is increase signal to pedal, you get same effect by pressing gas pedal harder. Pedal commanders are a known scam
delm
Atlanta
I’m honestly open to being moved by the information. I value your opinion. I respect where you are coming from enough to watch the video you posted. I just think that you are making some major leaps that don’t align with the video’s description as to why K&N is so effective.
you are trying to argue that a turbo functions like a vacuum, and the K&N is ineffective in a vacuum environment. I think you discard the fact that the engine does create the very vibration that makes the K&N superior in the first place, despite the “vacuum” function of a turbo. It does sound like a turbo in a controlled environment (ie, one without the engine) would render the K&N less efficient. But the fact is, the engine and its vibration exists. And that is the fundamental condition that makes the K&N filter superior to paper filters.
you’ve basically posted a video that goes into great length making a compelling argument from “the” authority on the topic that the K&N is a superior filter if used on a car with an engine. But then you point to what you call an inference that I don’t believe exists as a key point in your argument that a high quality paper filter is better. I really don’t mean disrespect, but you are saying that 1+1 = 5 with no dots to connect to get there.
I’m open to a good discussion, and I’m open to learning something. But I don’t like flawed logic or fallacies, and so I hope nobody reads this thread and is moved to think K&N are not superior air filters….based on anything presented here so far.
