Wiring prep pack
Dperry285
Dennis
2023 ford bronco sport
The wiring prep pack is listed under functional on the standard equipment section of the window sticker, ( 2023 outer banks) does anyone know what this is and whats it for
biglarrr
Larry
NW Indiana
You sure got that right. I've asked multiple Ford Service and Parts Counter employees. I've contacted Ford corporate, and nobody has given an answer.
OKay I have to take that back. I've been told it's for the wiring harness if you get the hitch package, but since I have the hitch package, and it doesn't require a prep kit, that didn't hold any air.
I was also told that it was for optional power seats on passenger side, but there is no option for power seats on any package for the Bronco Sport.
If you look at different window stickers, it's spelled differently, and even worded differently, but it's always there.
The only thing that isn't there is an explanation of what it is.
I think it might be for a manniquin, that you can put in the passenger seat and drive in the car pool lanes with.
Dperry285
Dennis
Somewhere i seen on this site its for a light bar if you install one
Yes, that is the answer. If you look on the top corner of the windshield on the driver’s side it is labeled. Not easy to get at and really not that useful in the end.
Dimo302
Chris
2012 Mustang Boss 302, 2022 Bronco Sport Big Bend
That’s what I thought it was for and I ordered the Rigid light bar from Ford while I was going through the purchase process. When the dealership went to install it, they said there wasn’t anything run up either A-pillar for it. It would’ve involved basically pulling all of the trim above the seatbelts to run the wiring.
edit to add this was on the Big Bend trim. The light bar specified Badlands only, but I wanted to try and the dealership didn’t charge me anything to do so. Maybe only the Badlands actually has the wiring run up the pillar (despite it being on my window sticker)?
Dperry285
Dennis
Could be
From memory, it required removing the a-pillar trim, headliner, and maybe roof rail(s) to get at the wiring. It was too much disassembly/reassembly for most folks to even consider doing it. I think that some here have just run the wiring down the a-pillar next to the windshield on the outside of the cabin.
jason202
Jason
Washington, DC
2023 Bronco Sport Badlands, 2009 Volvo C30 T5
Could it be for the accessory dashcam packages that Ford sells? I seem to recall that there are wiring harnesses hidden behind trim pieces for both front and rear dashcam installations.
CrazyKZ
Ken
Allen, TX
Here's a picture of the wording etched into the windshield with an error pointing to it.
This is on the 23 Badlands.
Ford Bronco Sport Wiring prep pack IMG_1373
jmhpi49
Ball Ground GA
The power passenger seat is an option for the OBX. I don't believe the base or Big Bend come with the passenger power seat.
Light bar on roof .
Find this section!
Ford Bronco Sport Wiring prep pack A0851DC6-BE65-4068-923E-D20D889761ED
Ford Bronco Sport Wiring prep pack 761F9259-9B47-4A30-801D-2B71D5240DF7
Ford Bronco Sport Wiring prep pack 6AE5CDBF-EDB3-48D9-BB96-958A548DAB00
tRex
Rochester, NY
I always thought this was only an encouragement to mount Ford accessories on the roof rails -- there's nothing else there, AFAIK. The Bronco (not Sport) has removable covers at these points to mount things like limb risers, etc.
Wiring "pre-pack" and "accessory ready" is just some marketing jargon they dropped on there. If you think it's anything like "ready", you ought to see the installation instructions for the official accessories. Here's a PDF of how the light bar goes on. The first 25 pages are how to take the car apart...
CrazyKZ
Ken
Allen, TX
Haha....I'm still laughing.
I keep a copy of those instructions because they are pretty detailed about how to remove basically every trim pillar panel and a few of the headliner and dash pieces. I can totally see it being helpful someday.
But I think people are expecting there to be a cap that snaps off and exposes some ISO designed plug that a ditch light gets power from and a drop down switch for it under the dash. It's "ready" in the same sense than an Escalade off the assembly line is "ready" to become an armored car.
