Climate Domain works! (On screen climate controls)
Jess1
SE Texas
F150
Took a bit of fiddling. Used the plain language version in Forscan on APIM module. It wouldn't take before, so "restarted " with engine on. Added Climate Domain first, then added each control in order.
Heated seats and steering wheel now on main screen, all other Climate controls available on screen.
Ford Bronco Sport Climate Domain works! (On screen climate controls) 20220411_135737
Ford Bronco Sport Climate Domain works! (On screen climate controls) 20220411_135746
Ford Bronco Sport Climate Domain works! (On screen climate controls) 20220411_135801
Fordson04
Jonathan
VA
I could never get this to work for me either I'll have to give it another shot this afternoon once my wife gets home since her car's in the shop and I work from home so she stole my car haha
Jess1
SE Texas
F150
It was a bit fussy - just powering up didn't work - had to do it with the engine running for each step... good luck!
Mlarv
TN
Which spread sheet are you using? I might give this a try also
Moltenburn
Denver
2022 BS BL w prem, 360, shelf. VW Arteon
Damn buddy. You the man for figuring this out. I have forescan tool and plan on digging into the system as well.
Jess1
SE Texas
F150
One more thing - at first on/ off cycle after adding climate, the center screen animation is a fade on/off Ford logo. The Bronco animation comes back after the 2nd restart...
alanovalles
Alan
Mexico
How did you add the climate domain? Is is simple to do for a regular person?
bjbena
Barry
Escape SEL. EcoSport SES
Just tried this today and it works. Spot on man!
Do you have forscan?
Yes I have FORSCAN and I have the adapter and forscan is installed on a laptop and works in my bronco sport. I have already done a complete backup of my module data and saved that.
Rodrigo_V_U
Rodrigo
Curitiba - Brazil
Ford Bronco Sport Wildtrak
any of you found a way to keep "recirculation mode" ON until buton pressed OFF? I always used it closed in my cars and in the BS it opens again after few minutes
bjbena
Barry
Glad it worked for you but can you please post detailed instructions for others to follow?
OP already said he did it via Forscan on the APIM module. "Used the plain language version in Forscan on APIM module. It wouldn't take before, so "restarted " with engine on. Added Climate Domain first, then added each control in order. "
Not much else to add.
