MNBroncoLady
Jennifer
Minnesota
www.flyingorangewebdesign.com
Probably the only other person I have ever seen a post from that has used Zaino. I have always had good results with it but I’m also always searching for something better.
Zaino is all we use on our cars. ??
thekingprawn
Dustin
Kingston, Wa
All I did today was drive a few hundred miles, turn a handful of donuts on the beach, and get it right filthy. Bath time tomorrow.
Ford Bronco Sport What did you do TO your Bronco Sport today? 294337078_416860520411400_4665156252792037330_n
spiritedcharm
Scarlett
Ohio
Bronco Sport Badlands
Added my Bronco and American flag decals today, I love them!
Ford Bronco Sport What did you do TO your Bronco Sport today? 20220423_160505
That looks so good! Is that from DiamondVinylDecals? What color is it?
Update: Disregard! I see your pic on DiamondVinylDecals, Mat Black
MHUNTOON
NC
Installed the Aeroskin II. After I finished, I realized I forgot to use the surface prep. I used the alcohol wipes, but not the other stuff. Is that going to cause a problem? Ugh.
Ford Bronco Sport What did you do TO your Bronco Sport today? A90DE035-DB44-4C46-843F-6F45D605CDE6
before
Ford Bronco Sport What did you do TO your Bronco Sport today? 882582BA-DE3B-4294-BA8C-2E7D21322BAD
after
the captions help, huh? Lol
before
after
I think you will be fine. You could have the same thing using Dawn dish soap. Just want to get all the wax if any off. If the vehicle is relatively new and hasn’t been waxed, you should be ok.
tennisbp
Brian
Seattle, WA
Replaced the stock Pirelli Scorpions with Toyo Open Country AT3s, 235/65r17. Too few miles to have a developed opinion on them, but so far, the ride is better overall. Small bumps are less noticeable (softer compound, larger size). There is a slight squirm when changing lanes at highway speeds, but that was expected when going to an AT tire.
Looking forward to testing them out in the wet and snow in the PNW.
I also put on a new hat, Yakima LocknLoad and Rail Kit B. The Rail Kit adds a whistling noise at around >35mphs, gets noticeable at 60mph. Pretty sure it is from the front rail only, which I might remove. Looking to add a Roam Cargo box up top soon and some pads for a surfboard.
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_0997-2
MHUNTOON
NC
It is and I haven’t. Hopefully the alcohol swabs were good enough.
klawrence27
Kyle
Central, OH
I put my Aeroskin 2 on as well.
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_2724
thekingprawn
Dustin
Kingston, Wa
Saw a BS looking a lot like your in Allyn yesterday.
