Elegance
Kris
Cactusjk
Jeff
Woodland Hills, CA
Appreciate the expertise from both of you. My current goal is "do the best I can" since it's being traded for the Badlands in a couple of months anyway. I did order a Chemical Guys wax along with my new foam cannon and soap, so I'll apply another wax coat once I've got it as clean as possible then call it good. My elbow grease today did work to remove the brown spots, but I'll give it another thorough wash when my new stuff gets here. My dealer is not going to get face-level with the paint and look for the most minor imperfections when giving me the value of my trade in under 5 minutes. As for the clearcoat, it's probably slightly thinner in the spots where I've removed the spores, but it is not visible and should be corrected by the dealership when they prep it to put out on their lot.
The Badlands, however, will likely be getting a ceramic coat. It will never not be kept in a garage. This 4 month work assignment was a special circumstance, but now I never have to live away from my own home ever again. Going to change up my care routine, wax regularly, ceramic coat the Badlands, and hope I never have to deal with Shotgun Fungus ever again.
I have had ceramic on a couple cars. Great stuff! However, on the BS I went back to Zaino since it is easier to maintain if you get a chip, scratch, etc. I also have used Zaino on my FJ since 2006.
Probably the only other person I have ever seen a post from that has used Zaino. I have always had good results with it but I’m also always searching for something better.
Cactusjk
Jeff
Woodland Hills, CA
Definitely not mainstream but I have had very good success. After a ZAIO base coat, one coat of Z5 Pro and Clear Seal all I ever do after that is use Clear Seal.
A professional Ceramic job is $1000+
Just another option.
MNBroncoLady
Jennifer
Minnesota
www.flyingorangewebdesign.com
Zaino is all we use on our cars. ??
thekingprawn
Dustin
Kingston, Wa
All I did today was drive a few hundred miles, turn a handful of donuts on the beach, and get it right filthy. Bath time tomorrow.
Ford Bronco Sport What did you do TO your Bronco Sport today? 294337078_416860520411400_4665156252792037330_n
spiritedcharm
Scarlett
Ohio
Added my Bronco and American flag decals today, I love them!
Ford Bronco Sport What did you do TO your Bronco Sport today? 20220423_160505
That looks so good! Is that from DiamondVinylDecals? What color is it?
Update: Disregard! I see your pic on DiamondVinylDecals, Mat Black
MHUNTOON
NC
Installed the Aeroskin II. After I finished, I realized I forgot to use the surface prep. I used the alcohol wipes, but not the other stuff. Is that going to cause a problem? Ugh.
Ford Bronco Sport What did you do TO your Bronco Sport today? A90DE035-DB44-4C46-843F-6F45D605CDE6
before
Ford Bronco Sport What did you do TO your Bronco Sport today? 882582BA-DE3B-4294-BA8C-2E7D21322BAD
after
the captions help, huh? Lol
