Tires: Are there any significant differences between 235/65/17 and 245/65/17?
Chook
Chris
OH
Quick question and sorry if this has been posted somewhere else - does the odometer need to be recalibrated for the 245's? Or should it be? Thanks!
Tigger
Tigger
Illinois
Chook
Chris
OH
Thanks Tigger!
Only if you want it to be correct. It’s more the diameter than the width, but if the ratio is the same (65), the 245’s will be slightly larger in diameter.
Chook
Chris
OH
Makes sense - thank you!
Chook
Chris
OH
Marceline @bronc0mad has 245/70/17's on his Badlands. I think they look great and it seems he's having no issues with rubbing etc. Anyone have any thoughts on 70's?
Ford Bronco Sport Tires: Are there any significant differences between 235/65/17 and 245/65/17? Screen Shot 2022-08-26 at 5.17.11 AM
The 70's will rub. Not all the time and not every day, but with the wheel turned and the suspension compressed, they will rub. That is not limited to trails/offroad either. If you are turning and encounter a bump, it could cause a rub. There are some that have modified the pinch weld to alleviate the rub but that pinch weld is part of the structure/frame of the vehicle. We don't know how much that modification weakens the structure.
Chook
Chris
OH
Great input - thanks Meanderthal.
Yes, and your felt liner won’t do you any favors either. If you aren’t going off road and fully utilizing your suspension, you are probably fine but, as Eric has said many times already, 245/65 is the safest way to go. And no, adding a lift on the BS doesnt change the problem.
Chook
Chris
OH
Thanks Escape2Bronco.
Rygar
Riley
Saskatchewan, Canada
Infiniti FX35
Few pics from one of our trips this summer. Had no issues on the overgrown, unmaintained, and untraveled norther trails. Definitely put the Bronco through the paces and had no issues or reservations about it's abilities once. Tires were very good. Probably the best all-round tires I've ever used tbh, highly recommended.
Ford Bronco Sport Tires: Are there any significant differences between 235/65/17 and 245/65/17? 20220724_062116
Ford Bronco Sport Tires: Are there any significant differences between 235/65/17 and 245/65/17? 20220723_211800
Ford Bronco Sport Tires: Are there any significant differences between 235/65/17 and 245/65/17? 20220724_062054
Chook
Chris
OH
Nice!
Chook
Chris
OH
Just got back from tire shop and went with the Falken Wildpeak AT3W's, at 245/65/17. Also bought the ODBLink EX and a small Window's laptop to attempt and change the tire size in the ECU (I'll report back later on the results). I did have to remove the liner (as someone here suggested) to get the spare to fit, but it did. Just barely.
I took a measurement yesterday of the space between the flange (?) and the front tire on the stock Pirelli 225's, which came in at 2". And today on the Falken 245's Its 1.5". Half-inch difference from the 225's to 245's, so seemingly no big difference. Don't have any load on it other than the RTT nor have I really taken it off-road yet, so haven't put it through the paces.
Lastly, there seems to be decent amount of room in the wheel wells, between the tire and felt. Not sure if the '22 Badlands are different than 21's, but no issue there.
Will report back if any of that changes.
Ford Bronco Sport Tires: Are there any significant differences between 235/65/17 and 245/65/17? 1
Ford Bronco Sport Tires: Are there any significant differences between 235/65/17 and 245/65/17? 2.JPG
Ford Bronco Sport Tires: Are there any significant differences between 235/65/17 and 245/65/17? 3.JPG
Ford Bronco Sport Tires: Are there any significant differences between 235/65/17 and 245/65/17? 4.JPG
Ford Bronco Sport Tires: Are there any significant differences between 235/65/17 and 245/65/17? 5.JPG
Ford Bronco Sport Tires: Are there any significant differences between 235/65/17 and 245/65/17? 6.JPG
Ford Bronco Sport Tires: Are there any significant differences between 235/65/17 and 245/65/17? 7.JPG
Ford Bronco Sport Tires: Are there any significant differences between 235/65/17 and 245/65/17? 9
Ford Bronco Sport Tires: Are there any significant differences between 235/65/17 and 245/65/17? 10
Ford Bronco Sport Tires: Are there any significant differences between 235/65/17 and 245/65/17? 11
Trancos2002
Andres
Argentina
Hi. What would happen if I buy only 4 tires 245 and leave the original spare tire (225)? Could I use it in case of need without problems?
