ScareCrow
Burl
Indiana
BS/Badlands
After about 20 test models, I finally got all the measurements and contours right.
That's the key!
Start out learning these things then you can upgrade when the time is right.
Good looking job with the switches........ :like:
Reactions: Jrl
Deleted member 6350
I finally installed the front mud flaps. The bottom hole is already there held in place by a push pin, just remove that pin an install the hardware that came with the Kit. Then drill 3 holes with the mud flap installed by the bottom screw as your guide holes and presto it’s done.
p.s. you don’t have to remove the front wheel you just have to turn the steering wheel all the way to the left or right depends which side you start with.
Ford Bronco Sport What did you do TO your Bronco Sport today? 0D4BAD3D-CF60-4A5F-8F84-40460496E373
Ford Bronco Sport What did you do TO your Bronco Sport today? DF068597-075D-489B-A559-C03D215DDBED
Ford Bronco Sport What did you do TO your Bronco Sport today? DBB24613-36DB-4EEB-A0D3-7CFEF114CE85
Ford Bronco Sport What did you do TO your Bronco Sport today? 76884C83-3788-49CA-A738-E957524133D7
Cactusjk
Jeff
Woodland Hills, CA
I installed my new awning and drove it to work at 75-80 to test it out. Couldn't tell it was on and didn't hear no extra noise.
Ford Bronco Sport What did you do TO your Bronco Sport today? PXL_20220608_134211243
Nice! Can you provide more details on how you attached./ brand, etc?
dakman
It's a yescomusa 6.7 x8'. It wasn't expensive, around 150.00 shipped. I'll see how it holds up after this weekends trip. It's mounts easily to the factory bar without installing noisy cross bars. I actually fabbed up brackets but they look just like the ones that came with it. I wanted it to sit a little higher. Took about 20 minutes installing by myself the first time. Will be faster removing or putting back on now. I'm not going to leave it on all the time, just for certain times I'll use it.
Ford Bronco Sport What did you do TO your Bronco Sport today? PXL_20220608_134142561
Cactusjk
Jeff
Woodland Hills, CA
Thanks! Looks great.
Would be nice to see awnings that attach directly to the rail like yours.
dakman
I didn't take a pic of the actuall mount. At lunch I'll take one and post it
Fuzzbear
Chris
Richmond, CA
2022 Badlands, '21 Badlands (RIP), '02 Ranger Edge
Finally got the hood deflector and door moldings attached -- originally bought for my 2021 that got totaled in September before I could put on the accessories, now added to my 2022.
I really, really like how the door moldings contrast with the hot pepper red color. I dearly miss the rapid red color my 2021 had and while I do like hot pepper red better than any other color that was available, it's been hard not to compare it to the rapid red that I loved. The moldings help a whole lot.
Now, I have over 50,000 FordPass points just burning a hole in my account. I'm debating what else to get -- splash guards? Fender flares? Rubber floor mats? (I'd get the floor mats in a heartbeat if it didn't mean having to store the carpet ones somewhere.)
Ford Bronco Sport What did you do TO your Bronco Sport today? 2022-06-06_09-52-09_631
Ford Bronco Sport What did you do TO your Bronco Sport today? 2022-06-06_09-52-39_824
These wide moldings are beginning to grown on me. Looks great.
HomePeace
Bay Area, California
2022 Bronco Sport Big Bend
I put them under the cargo tray
Ford Bronco Sport What did you do TO your Bronco Sport today? 20220607_182549
Fuzzbear
Chris
Richmond, CA
