Cactusjk
Jeff
Woodland Hills, CA
Ford Bronco Sport What did you do TO your Bronco Sport today? B497D0D4-6BDA-476A-B7A9-ECA799F6325E
Ford Bronco Sport What did you do TO your Bronco Sport today? 218EE15D-46D2-460B-A2CD-65D1FEB6F2F8
Ford Bronco Sport What did you do TO your Bronco Sport today? B11CD72E-0026-4926-82EE-DA87E2C3D2EF
finally got some decent weather. cleaned the engine bay, outside got the foam cannon. even used the tire foam leftover from the civic si.
i was much deserved, it did so good over our long crappy winter.
Did you just spray it down with the foam gun?
245/65 17. It fits flat, but sticks up about 1 cm or so.
Ford Bronco Sport What did you do TO your Bronco Sport today? F5032CD0-B9DE-4493-A8B6-2FE35DD3C0E0
Meant 17! FJ flashback. Well that looks pretty good. Might have to get the right size spare now.
AndyMac204
Andy
Ford Bronco Sport What did you do TO your Bronco Sport today? 304BAB94-4D4C-4AFF-8B5B-3E436CCCC9DC
used this, from a local hardware store. its one time use, burnt thru it last summer but rigged it for my soap lol.
wash mitt, and chamois.
and filled the tank with mid grade 89 octane.
$110 (canadian) with a 1/4 tank left. the most i ever payed for fuel in my entire life.
GR3EN
2022 Bronco Sport Outer Banks
That is too bad. I was hoping for the opposite.
After a but more driving around on some terrible roads is that it rides just about like stock in terms of small road imperfections, but it is much softer feeling on larger dips and bumps
christopheru
The Great White North
That is what I want to hear. Excellent and thanks for the update.
Makes sense. The cover rests flat with 235’s but I left the padding in below the tire.
Ford Bronco Sport What did you do TO your Bronco Sport today? DF959BA9-8160-4FCD-BA98-E440968139AA
dakman
Getting ready for it's first overnighter. Put together a brace to support the rear seats folded down with the bottom seat removed. Then built a table that's fits behind the pass seat and fills that large void to be able to use it for sleeping. Test the new mattress. At 6'1" I can fully stretch out laying down.
Ford Bronco Sport What did you do TO your Bronco Sport today? PXL_20220605_011140332
Ford Bronco Sport What did you do TO your Bronco Sport today? PXL_20220605_011109539
Ford Bronco Sport What did you do TO your Bronco Sport today? PXL_20220605_011743548
ScareCrow
Burl
Indiana
BS/Badlands
Ford Bronco Sport What did you do TO your Bronco Sport today? 397B8B35-0733-4360-B6C8-54A46A221319
Finally mastered my 3d Printer enough so I could make a custom fit bezel framing mount for my AUX light switch.
3D printers are pretty slick for this kind of mod's, what printer are you using if you don't mind sharing that info...... :thumbsup:
Pmk1710
Peter
Im cheap… got the Ender 3 3d Pro and some free CAD apps. After about 20 test models, I finally got all the measurements and contours right.
