- First Name
- Mark
- Joined
- Oct 30, 2021
- Threads
- 119
- Messages
- 6,733
- Reaction score
- 13,156
- Location
- St. Jacob, IL
- Vehicle(s)
- 2021 Badlands | 2020 Escape
Magnet size is generally not correlated to quality. The most powerful magnets used for speaker construction (neodymium) are also generally the lightest. Aside from material, magnet size is also influenced by power available, desired durability, and voice coil construction. The "right" magnet size takes all these into consideration.Believe me, the small magnets are just the start of the quality materials issues.
It's true that all other things being equal, a larger magnet generally means higher volume and finer control of the voice coil. But we are comparing two different speaker designs with different components. A properly speaker with a smaller magnet that's meant to function in a low-power system can have as good or better sound quality than one with a much larger magnet.
All of this is not to suggest the OE speakers Ford chose are "good." I'm simply noting that just because the magnet is small doesn't mean they are automatically "bad."
In looking at your post about replacing your speakers it's clear you did much more than simply change the speakers. A more fair comparison between the OE and Powerbase speakers would not include all the things you did that significantly changed the installation environment.Volume is definitely better now but so is quality when you turn it up over approximately 12.
