thekingprawn
Dustin
Kingston, Wa
thekingprawn
Dustin
Kingston, Wa
WinTech
Shawn
Washinton State
2021 Bronco Sport BB, 2022 Passport, 2023 HR-V
The USB-C port does in fact work with carplay, I've used a cable and currently have my wireless carplay adapter plugged into that port and it works fine. The one I have came with both cables and I noticed that it boots and connects way faster when plugged into the USB-C port.
thekingprawn
Dustin
Kingston, Wa
I'll need to try that. It's not entirely automatic connecting to bluetooth right now.
Cactusjk
Jeff
Woodland Hills, CA
Well that is good to know! Might have to order a USB C cable.
thekingprawn
Dustin
Kingston, Wa
When I start up the carlinkit throws a bunch of bluetooth connection pins, finally connects, then I have to select the phone on the touchscreen, but eventually I end up connected to android auto wirelessly. If it doesn't just work it may not be worth the money I paid since it takes longer to be connected than if I just plug in.
Even if it takes longer to connect, wireless is so much easier and more convenient.
thekingprawn
Dustin
Kingston, Wa
A minor annoyance: the device reports itself to the sync system as a Carplay system, and that's iBorg terminology.
Jafo
Greg
Oklahoma City
I didn't know that the Carlinkit also did wireless Android Auto! I am going to have to try this.
spiritedcharm
spiritedcharm
Scarlett
I think it's just version 4 that works with android
thekingprawn
Dustin
Kingston, Wa
I can verify it works with Android auto. Once it connects it's fine, but getting it to connect to bluetooth is not always frustration free.
brianloch1974
Brian
Butler, PA-USA
2022 Bronco Sport Big Bend
Did not power up.
I received my replacement and it connected flawlessly. I did install the update, and all is fine. Caveat, if you have the Wi-Fi hotspot due to the way it works you cannot use both simultaneously.
Which version adapter do you have? My Carlinkit3 will not work in the USB-C port.
WinTech
Shawn
Washinton State
I have the ottocast. https://www.amazon.com/Wireless-CarPlay-Adapter-Version-Convert/dp/B09Q59XY7Y/ref=sr_1_2_sspa?crid=MXFIIQB1XWYT&keywords=wireless+carplay+adapter&qid=1656563804&sprefix=wireless+carplay,aps,214&sr=8-2-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUExNTRJRTUwOEYyMUdDJmVuY3J5cHRlZElkPUEwODEyOTU2S1BFRVdNTFlTQllSJmVuY3J5cHRlZEFkSWQ9QTEwMzE3MDMxSDM4WkM0UjVQWkFEJndpZGdldE5hbWU9c3BfYXRmJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==
It has a usb-c port on it and comes with a usb-c to usb-c cable and a usb-c to usb a cable. Like I said it boots faster when plugged into the usb-c port. I also have a cplay2air and I got a usb-a to usb-c adapter but I haven't had a chance to test it.
