I've found that the description in the Owner's Manual for each drive mode is fairly accurate. I've also found that it's rarely necessary to use anything other than NORMAL.Has anyone figured out which drive-mode provides the least slip of the tire with the LEAST traction?
This is very true especially for the Badlands where you can hit the buttons around the goat mode knob when you need them.I've found that the description in the Owner's Manual for each drive mode is fairly accurate. I've also found that it's rarely necessary to use anything other than NORMAL.
As long as you haven't turned off traction control the computer will do that for you. The computer simulates locking differentials by applying the brakes to wheels that lose traction.Has anyone figured out which mode stops a spinning tire the quickest if it’s suspended in the air?
I’ve found Sand mode useful in deeper sand in narrow wash canyons to stabilize turning, slippery in 4in deep pea gravel for the same on ashelf road and, while normal would probably eventually figure out what to do… rock crawl helped on a couple slick steep steppy hills.I've found that the description in the Owner's Manual for each drive mode is fairly accurate. I've also found that it's rarely necessary to use anything other than NORMAL.
It's almost as if the engineers who designed the car thought of this. Wait...I bet we would all choose different modes at times to fit our skill level and style of driving.
Funny how that works out sometimes ain’t it?It's almost as if the engineers who designed the car thought of this. Wait...
