I will have to look for them! I found some on Amazon for like $95 but I don’t think they were stainless. Redline I think was the company.Love them, 100% worth it...do it!!
...though being in PA you may want to spring for the stainless steel since you get lots of salt in the winter I'm assuming
That's where I bought them. They're on Amazon too but I bought them direct from redline. The stainless are $139 direct from them I believeI will have to look for them! I found some on Amazon for like $95 but I don’t think they were stainless. Redline I think was the company.
Those look exactly like the Ford deflectors I installed. Cost me about $90 for the set.AVS low profile window deflectors.
Removed the logo but put a little goo be gone stuff on it then just used finger nail to scratch it off.
Thank you! I will take a look and see what I can find!That's where I bought them. They're on Amazon too but I bought them direct from redline. The stainless are $139 direct from them I believe
Goo gone... wonder if that will take the EGR off mine?AVS low profile window deflectors.
i think it would, the goo helps but finger nail does most of the work. Took less than a minute to remove each.Goo gone... wonder if that will take the EGR off mine?
Thanks
keep us posted on how it performs! looks solid ??Installed the JLT Air/Oil Separator,
was quick an easy to install.![]()
Just a quick dress-up thing, but like many other Ford owners, I'm not a big fan of the factory lug nuts, especially after a particularly annoying experience on the side of a freeway once where the little metal cap stripped off while trying to change a flat.
I've had very good luck with VMS Lug Nuts on my other cars and treated my Badlands to a set of red ones:
I don't get the purpose of these, especially since the 1.5L engine includes a factory air/oil separator.Installed the JLT Air/Oil Separator
I installed the JLT on my Big Bend at about 3k miles. I have 10,650 now. The can has filled 3-4 times. Keeps the oil and vapors off the valves in these direct injected engines.I don't get the purpose of these, especially since the 1.5L engine includes a factory air/oil separator.
https://parts.ford.com/shop/en/us/engine/other-engine-parts/separator-assy-oil-12014655-1
The oil pulled out of the PCV system by the OEM air/oil separator goes back into the sump instead of into a can that you must empty. Yes, the oil contains contaminants, but this engine has a relatively large sump, and the oil is designed to hold contaminants in suspension until you change it. The recommended change interval accounts for oil contamination, and as long as you change it at the proper interval the contaminant level will not harm the engine.
