curtcady
Curt
Belfair
2021 Bronco Sport Outer Banks
Pretty much echoing what others have said here. We have a 21 OB, 42k miles, extended warranty. In the spring of '23 during a service we asked the service dept to look into that noise issue. Not sure if they did.
September of 23 we had an appointment specifically to address that noise. They didn't find anything and was charged a $200+ diagnostic fee
Then in October '23 I was searching this forum and found the TSB that was issued in August 2022. We scheduled an appointment for December 13th to get this fixed. We took the vehicle in, they had for two days and called us the evening of the second day saying they didn't fix the brakes because they didn't have the parts, then wouldn't release the vehicle to us because they JUST ordered the parts and we needed to pay for them, THEN reschedule another appointment (mind you this was after us informing them we were switching to another local dealer for service.
After discussing it with a sales manager, we got the vehicle released to us.
There is a systemic problem with these service centers not doing their homework and researching TSBs prior to any service, and the service managers complete lack of problem solving know how.
cprcubed
Patrick
Parker, TX
Dated 09 October 2023 and states “This bulletin supersedes 23-2041”
What is the number of the posted TSB? (I somehow missed it). Cheers!
cprcubed
Patrick
Parker, TX
I found it. It's TSB 23-2308. Cheers!
cprcubed
Patrick
Parker, TX
I edited my post above. Cheers!
New information …
Ford Bronco Sport So many problems - Need to find help 1703180704635
I think the only question i would ask is in what position should the reenforced bushing go ? Top or bottom ?
Tamztrk
Tamra
Ca
I've seen a few mentions of the recent TSB regarding brake noise. Here's the full scoop!
Ford Bronco Sport TSB 22-2326 : "Moan Noise in the Rear Brakes When Driven in Reverse in Cold Weather or High Humidity" Screenshot 2022-10-24 144733
New parts:
Ford Bronco Sport TSB 22-2326 : "Moan Noise in the Rear Brakes When Driven in Reverse in Cold Weather or High Humidity" Screenshot 2022-10-24 144843
C
New parts:
Corey, thank you so much! I needed “receipts” and someone posted this previous but I couldn’t find it.
thanks again, I knew you guys wouldn’t let me down ?
Tamztrk
Tamra
Ca
Thank you , that’s the first I have seen that write up . Had mine done in 2021 oct .
I was told my parts were in a couple of months ago…..then they weren’t. I was told they had been redesigned and on backorder. Make me believe they weren’t giving them to other owners ?
C
@Tamztrk .. as mentioned on another thread, TSB 22-2326 and TSB 23-2041 are both superceded.
TSB 23-2308 is current for this issue:
Moan Noise In The Rear Brakes When Vehicle Is Driven In Reverse (R) In Cold Weather And/Or High Humidity, Supersedes 23-2041
https://static.nhtsa.gov/odi/tsbs/2023/MC-10244711-0001.pdf
Tamztrk
Tamra
Ca
Dude, to clarify, is this info an update (or different). Thank you for taking the time. I appreciate you ?
That’s something you will have to discuss with your dealership service department if you are concerned about the rear brake noise.
Print a copy of this PDF and bring it with you,
For more discussion see this thread: “Finally”… a correction for Rear Brake Moan Noise” and in Post #8, Mark S stated the following: “ The kit also includes new caliper springs, which are meant to pull the pads back off the rotor when the driver releases the brakes. The noise is a resonation created by friction between the pads and rotors, so it's possible this kit includes stronger springs to reduce that friction. I'd be interested to see of the new springs are stronger than the OE springs.”
https://www.broncosportforum.com/forum/threads/“finally”…-a-correction-for-rear-brake-moan-noise.10230/
Only Ford knows exactly what TSB 23-2308 is going to do for the rear brake noise. That’s why you need to discuss TSB 23-2308 with your dealership service department.
