Tire Pressure from Factory
Warpious
www.floracreekplace.com
Looking at the tire pressure from the factory, the tires are at 41-42 psi...that seemed a bit high to me, anyone else experience this? Should I let some air out or is it just because they're new and after a few miles they'll drop off naturally?
retiredguy
My tires were all different PSI when I took delivery. I adjusted the pressure to the recommendation level.
Michigunman
Georgia
Set them to what is on the sticker insider driver door. Tires should be as close to "cold" as possible.
Be sure they are cold when checked. Depending on conditions, if you've been driving the pressure can go up six or seven pounds.
If that is the cold tire pressure reading, that is the psi needed to seat the tires during installation at the factory.
The tire pressure should have been readjusted during PDI at the dealer to what the placard psi values are.
jayzala
IL
2022 Outer Banks
I let out a lot of air in my tires, they were 40psi when I took delivery.
I believe they over inflate them since they will sit on the rail car while it is in transit for a while so they don't want any flat spots on the tire when it is stationary for a long time.
Jess1
SE Texas
F150
Correct. Dealer should then adjust during PDI, but hey...
Flash
Mine were at 35PSI when I bought it.
DISCOLEG
The pressure is set high during transportation to keep vehicle stable.
Dealers are supposed to deflate them to 35.
PonyDriver43
Roger
NE FLA
42 PSI all around when picked up. PDI was formality. Reset to 33 PSI (per door sticker) after nite in garage. Rides nice now.
Come on guys, these vehicles sit unattended for months. Tires all loose a little air over time.
And,
If they put 33 psi in them they’d wobble all over the car carriers, chains would get loose.
You all got over filled tires because the lower paid workers who prep cars at your dealership don’t give a crap anymore.
They pull it in the shop not caring that the hot sun on one side raised the tire pressure by three or four psi.
Caliope
Lisa
Illinois
Tire pressure was an issue back in '19 when I got my Ranger. Rangers are built in Michigan, so the over inflation has more to do with seating tires initially. I also think the higher pressure works better on the assembly line as well.
barry
barry
georgetown, de 19947
2021 bronco sport
Mine was 42--they due that so they dont bounce too much while on the transport carrier--The dealer is supposed to change the tire pressure upon new car prep
jazzdab
Thom
Raleigh, NC
I completely understand the high pressure during shipping but I expected the dealer to adjust the pressure prior to delivery. Then again, I have developed a habit of checking tire pressures myself before AND after every service. I have routinely found tires under or over inflated following service. Not sure if it is pure incompetence or an attempt to sell more tires.
