SYNC 3.4 Build 22251 now available.
The update is now available for download through Wi-Fi with the head unit. I used the above link and followed instructions to copy the files to a USB-A or USB-C flash drive to update.
Ford Bronco Sport SYNC 3.4 Build 22251 Now Available 1/22/23 2515F777-4546-49D9-BCC1-B607BB3F3DC3
It seems zippier. SiriusXM screen detail refreshes faster. SiriusXM Travel Link is much faster and smoother.
Ford Bronco Sport SYNC 3.4 Build 22251 Now Available 1/22/23 AD1A92B4-6F0E-491D-8E02-48A8844E128D
Ford Bronco Sport SYNC 3.4 Build 22251 Now Available 1/22/23 5909D265-F520-402B-B6CC-6AB92D9B85EB
ScareCrow
Burl
Indiana
BS/Badlands
The update is not yet available for download through Wi-Fi with the head unit. I used the above link and followed instructions to copy the files to a USB-A or USB-C flash drive to update. View attachment 33888
I sure wish they would provide release notes/list of changes.
Really annoying that they don't....... ?
This update has been available since at least November of last year, so your BS may already have it. Make sure you need to update before going through all the steps to update.
Actually not directly from Ford. A version of 22251 has been available through CyanLabs for download. Build 22200 was released in late October for download from Ford. This 22251 update and link will download an official Ford version from the Ford website.
Fordone Badlands
Ontario
22 Bronco Sport
Followed online instructions with USB. After having to remove it once and plug back in, finally the update got done.
Thanks
JWPVB
Judah
Florida, USA
So is it from Ford or CyanLabs ?
If it is not from Ford wouldn't it be prematured yet to install without Ford "blessings"?
DBBLTAP
Jack
Scottsdale, AZ
2001 MFE (Mighty Ford Escape)
THIS ISSUE HAS BEEN RESOLVED: THANKS TO ALL WHO HAVE COMMENTED!!! Using WIN-11 latest build, I re-downloaded the update file from Ford, used yet another USB Stick (exFAT), and decompressed files using Windows Explorer. I checked the stick and saw that Win-Ex did decompress & xfer the Folder to the stick, but Not the two smaller files. I manually drug the small files to the stick, and Now my Badlands is "Updating System Software." How Sweet It Is.....!!!
P.S. Don't forget to go into System/Engine settings and turn OFF the selection to shut down the engine after 30mins. My update took 60mins. Ended with a blank screen. Shut off enging,, opened the door, waited for the instrument screen to go blank, then started up with a fully functioning updated SYNC3.
Original message:
I am unable to update my '22 Badlands with the new 22251 build. I get the message "This USB device is not compatible. Please Remove." Removing/replacing the USB stick did not help.
I formatted my USB stick to exFat, copied the "Extracted" files to the stick. I already tried two different Sticks, and two different Extraction apps. I'm at a loss.
Any ideas would be appreciated!
Thanks in advance.....
JWPVB
Judah
Florida, USA
Just in case: Use a brand name (like SanDisk) compatible with USB 3.0
Fordone Badlands
Ontario
22 Bronco Sport
Mine came from the Ford site.
Fordone Badlands
Ontario
22 Bronco Sport
Make sure your usb stick is at least 8Gb and is formatted exfat.
If you read the instructions from their help file, you don't extract and copy. Using Win explorer, select and extract to the USB stick , root level.
Fordone Badlands
Ontario
22 Bronco Sport
Use the help file attached previous. The only part I couldn't get to work was at the end, doing the confirmation of the update back to Ford. Kept getting an error. Why??? Who knows.
SYNC is notoriously finicky about USB drive quality. Make sure you are using a high-quality, high-speed device.
Is the downloads page (attached) displays the build before the update?
Ford Bronco Sport SYNC 3.4 Build 22251 Now Available 1/22/23 Doc1
The SYNC 3 version is not always displayed on Ford’s download site
My ‘22 Badlands came from the factory with version 21194.
In October 2022 I installed version 22200 via USB Device but after the 22200 install completed, i was not able to upload the created file from the USB Device to the Ford site due to a known issue with Fords website. So my download page showed “blank” at the spot in your pic where you show 3.4 22200. I contacted the Ford software support team in October 2022 but they could only explain it is a known issue.
Today 1/23/2023 I installed version 22251 via USB Device but after the 22251 install completed, i was not able to upload the created file from the USB Device to the Ford site due to that known issue with Fords website as I mentioned earlier.
And my download page shows “blank” at the spot in your pic where you show 3.4 22200. But I do have 22251 installed as confirmed by the setting on the 8” Display.
JWPVB
Judah
Florida, USA
Hi "Dude"
Thank you - I was confused after Thomasm23 wrote:
"Actually not directly from Ford. A version of 22251 has been available through CyanLabs for download"
I will try the Ford link later.
