- First Name
- Adam
- Joined
- Oct 2, 2023
- Threads
- 11
- Messages
- 35
- Reaction score
- 20
- Location
- Houston, TX
- Vehicle(s)
- 2021 Ford Bronco Sport
- Thread starter
- #1
Just got my 2021 Bronco Sport OBX back from the dealership. Entire transmission and torque converter had to be replaced. This is a daily driver, so very surprised that I had these issues. Thankfully everything was covered by warranty, including loaner vehicle.
Explanation on service paperwork:
Concern:
Cause:
Correction:
Tech Notes:
VCM to check for DTCs none found. Reprogrammed solenoid strategy and cleared adaptive tables. Concern still present. Monitored on datalogger. Torque converter is causing shuddering and delayed shifts. Removed transmission. Mounted on bench fixture for teardown. Found torque converter damaged internally, no. 15 bearing dug into transmission case, no.4 bearing burnt, no.1 bearing burnt, output planetary bearings worn out. Direct clutches and forward clutches burnt. Cost cap directec to repair, but due to parts availability, transmission replacement was required. Proceeded to replace transmission, reprogram solenoid strategy and clear adaptive tables post road test to verify repair.
Concern:
- Customer States SHUDDER FEELING WHEN DRIVING - TECH 127 ROAD TESTED
Cause:
- shuddering while driving and erratic shift delays Replaced transmission due to parts availability
Correction:
- Automatic Transmission Assembly - Remove and Install or Replace
- Extra Time For A Post-Repair Road Test.
- Extra time to mount transmission on a bench fixture
- M time for disassembly and assembly of core for return shuddering while driving and erratic shift delays connected
Tech Notes:
