Right rear shock replacement follow up
I had a previous post about the right rear shock leaking on my 2025 BL with 6800 miles.
Took it in Monday for my appointment. They called me mid-day Monday and told me the shock is not in stock at their San Diego warehouse.
Not encouraging. Since it is a warranty replacement, they would expedite it from Detroit via Fedex.
It did come in this morning, it was replaced and I picked it up late morning today.
I give them credit for doing all they could to find the part. Never any issue with the warranty.
Looks like another replacement part that is in short supply.
Before & after pics. I didn't pull the tire to check the new shock so the photo isn't great.
Ford Bronco Sport Right rear shock replacement follow up 10
Ford Bronco Sport Right rear shock replacement follow up NEW SHOCK
Glad it’s fixed!
…and then there’s me… covered the whole underside of the vehicle in fluid film to prolong the inevitable rusting that occurs in the Midwest.
Fluid film is an oil coating. So, my struts and shocks look like your first photo. 🤣
Glad it’s fixed!
I’m from Iowa originally so I lived the rust belt life.
I would do whatever was necessary to save the mothership from crumbling into pieces if I was still there.
Sad that the original shock failed so early.
Good for you to get it taken care of fairly quickly.
Larry N
2025 Bronco Sport Badlands, 2020 Tahoe
Thanks for pointing out something to keep an eye on.
The only reason I found it was I took the tire off to get a leak fixed. If you rotate your own tires it will be obvious.
Mitchjd2
Mitchell
2010 Ford Sport trac
My rear shock failed because it was coming detached from the car. Ford fixed it
bronc 2025
Thomas
2025 Ford Bronco Sport
I know in my Big Bend I would like to replace all the shocks with something different from stock
winn70
Nth Iowa
2023 Ford
Replaced both of ours at 15,000-20,000 miles
bronc 2025
Thomas
I would love to put better shocks all around
