- First Name
- Mark
- Joined
- Oct 30, 2021
- Threads
- 119
- Messages
- 6,727
- Reaction score
- 13,163
- Location
- St. Jacob, IL
- Vehicle(s)
- 2021 Badlands | 2020 Escape
Your car likely has both a vacuum-powered brake booster (US driver's side of firewall) and a separate ABS module (US passenger side of firewall). I believe cars with 360+ use a brake booster that incorporates ABS, all in a single module. In addition, I believe cars equipped with 360+ also tie in to the factory navigation system, so if you don't have that installed you may run into further programming issues.Hi all!
I am new to the forum and first time writing on a forum, I got my 22 Badlands in June. Since then I did some modifications including changing the climate control panel, and Forscan programming.
Since this is my first Ford vehicle, I am still learning.
I am working to install ACC to my Bronco Sport.
Thank you My42waffles for pointing the right direction to get parts. I managed to get the steering wheel control, front sensor and the bracket.
Here is the photo of the Steering wheel button.
However the ACC harness includes two parts. The first one is 14290A and the second one is 12A522
Attached is the wiring photo
I took apart the front of the car to check, in order to change the 12A522 wire, I need to take apart the radiator. I didn't get the harness.
So I made my own harness, Cat6 cable for Can High and Can Low, and 20AWG Automotive cable for power. Fortunately, when I got my sensor from a junkyard, I managed to get the connector with the sensor.
I am now connecting the sensor directly to IPMA above the interior rearview mirror.
Right now I have all the hardware wired up and installed
Here is a photo of the sensor (Pardon me for the awful wiring, I will take the front apart again, label things up, do proper waterproofing to the wire, take some photo and tidy things up)
I did cut out a slot to fit the bracket. Thankfully, there are existing marks on the cover, So I followed the mark to cut it out.
I don't have the sensor cover right now, I ordered it but it takes a long time to get here. When the sensor cover comes, I will cut out the center to fit the cover nicely.
After contacting Forscan Team, I managed to get a test version of Forscan to do Front Sensor Calibration.
Below is a picture of when I am doing a calibration early this morning, you want a straight road and a constant speed above 30mph. I used Ford's calibration document to do it. The calibration took me around 15 minutes to complete. And the warning message disappeared from the cluster. I also cleared the DTCs.
I am still in the process, the system is not fully working right now, I have managed to fully program the APIM, BCM, SCCM, IPC, and CCM.
The IPMA and ABS are finished yet since I have a cheap OBD cable, that might be the cause. I am waiting for my OBDLink EX to arrive today, then I will give it another go.
For the IPMA, I am not sure if my module has the capability to do it. Right now, if I enable ACC in IMPA, the front camera will stop working.
I don't know the module part number for cars equipped with CoPilot 360+ Assist, if somebody can help with that I am greatly appreciated it. My IPMA is M1PT-19H406-CD
Here is a photo of the Instrument Cluster with ACC programmed.
Currently, I cannot program the ABS, so I am actively contacting Forscan to figure out if that's a software limitation or a hardware limitation.
For the ABS itself, I know that my unit doesn't have an electronic booster. That means Stop & Go will not work properly or even the entire thing will not work. If that's the final roadblock I will figure out how to change the ABS module.
Now my vehicle with the new stuff installed, the normal cruise control still works. The buttons on the steering wheel control all work properly. I just disabled the ACC on my Drive Assist page for now.
When I figure out everything and make it work, I will do a proper write-up for this project.
Cheers!
