- First Name
- Mark
- Joined
- Oct 30, 2021
- Threads
- 120
- Messages
- 6,729
- Reaction score
- 13,193
- Location
- St. Jacob, IL
- Vehicle(s)
- 2021 Badlands | 2020 Escape
Turns out it's not easy to get a decent photo of it. It's mounted on the firewall almost directly behind the battery. The photo below is is the best I could do. It's take from the middle of the engine bay looking back and toward the driver's side.When you get a chance can you post up pic of vacuum brake booster?
You can see the fluid reservoir in the upper right of the photo. The two small-diameter tubes that come down out of the reservoir and bend 90 degrees to the left run to the ABS module on the passenger side of the engine bay.
The photo below is the brake booster on a Ford F-150. If you could get all the stuff out of the way, the one in the Bronco Sport would look very similar. The vacuum hose on the Bronco Sport is in the same place as in the photo below.
