- First Name
- Colt
- Joined
- Mar 26, 2023
- Threads
- 44
- Messages
- 529
- Reaction score
- 942
- Location
- Washington
- Vehicle(s)
- Bronco sport
- Thread starter
- #1
Mabett LED Grill Lights for Ford... https://www.amazon.com/dp/B0BW52Y7K2?ref=ppx_pop_mob_ap_share
Shout out to @JohnSilver for the guidance. Dremeled out the grill little by little til the lights slipped in and applied permatex adhesive/sealant. I
used painters tape and a tape measure to make the template and make sure everything was as even as I could get it. @JohnSilver recommended going as flush as possible to the top of grill, which was helpful in keeping the lights level.
These specific lights are meant for the big bronco and to be ran to the engine bay fuse box. I routed them through the firewall to the interior fuse box in the #3 slot. (Bottom of #3 fuse slot is the 12v side, which is important to know when installing the supplied fuse tap)
Now here’s the one issue, the supplied wires are about 1” too short to reach fuse #3 unless it’s pulled pretty tight. So here soon I’ll have to solder in extra wire so it’s not such a tight fit. Also finding a ground in the fuse box with the minimal wire to work with was a challenge.
im not super knowledgeable on vehicles, every project is a lot of trial and error so idk how much I’d trust anything I'm even sharing here but finding sources on putting raptor lights on a big bend grill was few and far between so figured I’d throw this out there ?
